A-C Turbine Status
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: A-C Turbine Status
    Posted: 19 Jul 2022 at 8:58pm
I"ll probably be shamed for putting this subject in the tractor section.  However, I think most of you have heard on the news about the explosion that took place at the Hoover Dam today.  And. of course the Hoover Dam is still being powered by those mighty Allis-Chalmers turbines yet.  Has anyone heard a status on their health and well being?  Was there any known damage to them?  Hoping they are safe and still running.  Thanks in advance for any status report!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 9:07pm
i thought they said on the news that it was a TRANSFORMER outside on the deck... and no internal damage to the Plant ..
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 9:11pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jul 2022 at 9:16pm
I haven’t heard of this. That stinks
Stan R View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan R Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2022 at 6:36am
Power plant transformers are usually protected by concrete barriers so that if they explode and/or start on fire, they don't wipe out other critical items. Sounds like these were designed as such??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 20 Jul 2022 at 8:14am
YES... normal mode of failure is not "explode".... it is to catch fire due to overheating... They have 1000's of gallons of oil inside ( as cooling and insulation)...  EXPLODE is a Media term for effect.... It is possible, but not normal.... they usually set on the OUTSIDE of the building wall in a row, OPEN to weather.
Edited by steve(ill) - 20 Jul 2022 at 8:16am
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2022 at 7:10am
It's being reported as a transformer, but that doesn't look like a transformer to me, looks more like a line circuit breaker.
Either way, they're filled with oil for cooling and insulation, and they DO get hot.  If it's a breaker, there's about a 100-gallon compressed air reservoir and fast-acting valve in there to throw the breaker arm open AND extinguish the flame (of the electric arc that results).
Notice that all the other breakers look just fine, but this particular breaker has a water sprinkler pipe above it?  I suspect this breaker gets some pretty heavy loading.
Be that as it may, Lake Mead is extremely low, and if it falls much further, they'll no longer have sufficient fall elevation to run any of the turbines.
tbran View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote tbran Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jul 2022 at 9:22pm
More electric cars/tractors/trucks are the solution... :-)
