Proper sediment bowl assembly for 615?
Dean (West MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dean (West MI) Quote  Post ReplyReply Direct Link To This Post Topic: Proper sediment bowl assembly for 615?
    Posted: 29 May 2022 at 7:27pm
Does anyone know if the 615 uses the shorter sediment bowl assembly like a B, or the longer one like D17?
Looking online, the I600 is listed as using the shorter sediment bowl assembly, while the D15 Series II (same engine as a 615) uses the longer assembly.
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 30 May 2022 at 9:23am
The larger engines have more fuel flow. With the biodiesel and the ethanol in the gas, you will need all the capacity to trap jell and dirt.
Curt Anderson
HD3, HD5B, HD6AG,HD6B dozer, I-400,615, 616,620,720,ACP25 lift truck, 1956 D Grader, AC 540 loader, AC #84 plow, Simplicity tractors, Agco MT225, Agco 2025,
This page was generated in 0.607 seconds.
