23.1x30 replacement?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Topic: 23.1x30 replacement?
    Posted: 22 May 2022 at 7:09pm
Is a 600/70r30 a good replacement size for a 23.1x30? I wouldn't mind if they were a little taller or just slightly narrower.
Edited by DanWi - 22 May 2022 at 9:33pm
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 23 May 2022 at 9:33pm
I think they will be a bit shorter and narrower.
I believe a 620/75 or 80 R30 would be closer to the same, but I frankly have never seen that size and not sure it exists.
the 600s are getting to be quite popular on newer big MFWD, so a used set for a good price would trip my trigger for sure. If 2wd the small size difference wouldnt matter.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
This page was generated in 0.048 seconds.
