D12 Series 3 Hydraulic Issue |
NormJ
Topic: D12 Series 3 Hydraulic IssuePosted: 22 May 2022 at 9:40am |
Loader and 3 point has no lifting power. Oil and filter are good. Tried cleaning and adjusting adjusting relief valve, no pressure at gauge plugged into remote. Replaced relief valve, no change. Pulled pump and brought to hydraulic shop, checked out good. Loader will come up a little with my help, disc on 3pt barely moves. Disc will lift when draft control lever is pulled all the way back. Tractor has traction booster. Any ideas?
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54422 |
Posted: 22 May 2022 at 5:00pm |
Thw traction booster linkage must be adjusted right for everything to function. What is right? I never understood the instructions, just move the linkage some with the TB lever, and try again. Also this linkage tends to bind, so spray some of your favorite penetrant on it, too... Trial and error...
