leaking injector on 7020
Magnuson_2007 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Magnuson_2007 Quote  Post ReplyReply Direct Link To This Post Topic: leaking injector on 7020
    Posted: 06 May 2022 at 2:04pm
My 7020 has started leaking antifreeze/coolant from around one of the injectors. Ive tried tightening the two bolts holding it in with no change. Wondering if the olives at the top of the injector work as a seal and a dust cover?
The tractor has no white smoke. No overheating. No milky engine oil but it does bellow out black smoke if under pressure? Wonderiging if its a bad injector or head gasket Or the pre cups?
Any help is much appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 2:32pm
7020's have swedged copper sleeve for injector hole surrounded by antifreeze...say you have a sick one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Magnuson_2007 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 2:40pm
yeah I was thinking its the sleeve. Is it a big job to change them?
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 2:47pm
head removal. I'd be trying some ceramic seal to seal it up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Magnuson_2007 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 5:11pm
I will take a look and see what I find in there. Thanks for the help
This page was generated in 0.252 seconds.
