190XT pump timing
 Rating: Topic Rating: 1 Votes, Average 3.00  Topic Search Topic Search  Topic Options Topic Options
cwgage View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Topic: 190XT pump timing
    Posted: 03 May 2022 at 1:34pm
I have a 190XT that I recently put a low hour engine out of a generator in. I’m a IH guy and didn’t know a ton about AC engines going in, and didn’t know about Roosamaster pumps liking to fail when run after sitting a long time. Long story short, I had the pump rebuilt, and now I can’t for the life of me get it to run. It’s timing related, I’ve eliminated everything else. I know it’s got to be timed to 26 degrees advanced, and it there. The tractor will blow some blue smoke and sounds like it wants to fire, but just cranks. I’m stumped. Help please
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 2:33pm
So did you align timing marks in pump window before removal and then NOT turn engine while pump was off? I think its possible to force pump on 180 out but not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 3:16pm
Yes, the pump was pulled, rebuilt, and I re lined up the marks. Everything’s where it should be according to what I’ve seen online and in what’s left of my shop book for it. I’m honestly stumped. I’ve done pumps on 400 series IH engines before and never had a problem.
CORLEWFARM View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORLEWFARM Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 5:04pm
180 out they turn 1/2 SPEED of engine
orangefor life View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangefor life Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 6:00pm
your timing problem  out 180 degrees. Did you check  timing marks on pump before you removed it ? .it got to fire on  number one at 26 dg ,
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 6:33pm
Thanks. I wasn’t the one who pulled the pump, my father was, and I’ve got it how he and the internet say to put it. I’ll try flipping it 180. That’s gotta be what it is.
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangefor life Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 6:46pm
They are tricky . i had a run in doing the same thing years ago ,you know young an know every think lol. Just Thinking out loud here I pulled number inj out hold my finger over the hole an crank easy till it blow my finger off the hole an check the timing mark on fly wheel degree an pulled the timing cover of the inj pump off it was  off probley haft turn good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangefor life Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 6:48pm
Originally posted by orangefor life orangefor life wrote:
They are tricky . i had a run in doing the same thing years ago ,you know young an know every think lol. Just Thinking out loud here I pulled number  one inj out hold my finger over the hole an crank easy till it blow my finger off the hole an check the timing mark on fly wheel degree an pulled the timing cover of the inj pump off it was  off probley haft turn good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 8:21pm
Thanks. I was planning on sticking a welding rod or somethin down the injector hole and watch till it was up. That probably a better idea than mine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 May 2022 at 9:15pm
I'd rather pull valve cover and see when #1 int & ex are both loose. #6 should have a tight pushrod. You are aligning the 2 marks inside pump right? Behind the little cover. Pointer and degrees on front should be @ 26 deg. Don't those have elastomer ring on pulley with timing marks? They can slip and move when old.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 9:27am
above mentioned plugging the hole with finger, is the best method, because you know it's the compression stroke, not the exhaust. Just because piston is coming to top doesn't mean much lol! Dampener could have slipped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 11:40am
Forgot to mention I pulled the valve cover off. Might be that that ring slipped too
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 1:28pm
I hooked a timing light up and it’s way off. That ring must have slipped. Got it almost firing right now. Playing with it a couple teeth at a time
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 1:31pm
A timing light on a Roosa is almost useless. The only way it is accurate is if you were loading it on the dyno to full load, then the roosa pump is at true beginning of injection. It will get you close though. I'd guess about 15* BTDC idling on a timing light. Pull the injector, use the welding rod trick to verify tdc mark on pulley. It's not exact, but it will tell you if it's slipped.
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 1:38pm
Thanks will do
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2022 at 2:01pm
If you determine the ring has slipped,you better replace it with a good one. Bad harmonics do bad things!
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 1:27pm
As it turns out, Im stupid. The guy who rebuilt the pump for me left a sharpie mark on the pump shaft and o was using that as my pump timing mark. Thanks for all the advice anyways. On another note, after I had it running for a couple minutes, the pump shaft walked out. I’m not missing a trust bearing or anything to my knowledge. Any ideas why?
Edited by cwgage - 06 May 2022 at 1:42pm
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 2:03pm
In the end of shaft you should have spring and thrust button to keep the shaft in the pump
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwgage Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2022 at 2:15pm
Gotcha. Don’t have one. I’ll get my hands on one
This page was generated in 0.057 seconds.
