Rotary Hoe
Allis Fever View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis Fever Quote  Post ReplyReply Direct Link To This Post Topic: Rotary Hoe
    Posted: 24 Apr 2022 at 11:11am
I recently purchased an AC Snap Coupler rotary hoe.  The hub on one of the hoes is broken and I'm trying to find a replacement.  Online searches and a trip to my local dealer has produced zero results.  The hub is not threaded and is round (1.5" diameter I think).
The local AGCO dealer could not find it in his parts catalogs (after a valiant effort) and it might be (probably is) older than the D-17 series implements guide he was looking at.
Does anyone have guidance on where I might be able to find a replacement or parts number for it.  I've not found a model or serial number on the hoe.  Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Apr 2022 at 8:56pm
I have a hoe that might have the part you need.                    MACK
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2022 at 3:19pm
I have an owners manual for a snap coupler hoe that also has part numbers in it.
339372 is the part number for the "wheel assembly" or the hub that has all the spikes on it.
My hoe has wood blocks for the bearings, but the parts in this manual there is an actual bearing of some kind, so I can't guarantee that yours is the same
This page was generated in 0.095 seconds.
