Wd45 crank
d17brown View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote d17brown Quote  Post ReplyReply Direct Link To This Post Topic: Wd45 crank
    Posted: 04 Apr 2022 at 3:40pm
What is casting number on a wd45 crank
phil
JK in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JK in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2022 at 4:49pm
226535 is the main one. There are a couple of others depending on original use as per tapered hole, woodruff, or key way in nose.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2022 at 8:57pm
Never saw a keyway in a 45 crankshaft, only D17 and up.                MACK
