190XT clutch
NDBirdman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Topic: 190XT clutch
    Posted: 24 Mar 2022 at 5:22pm
Fired up the 190 today to remove the snowblower and put her up for the summer.  This time I paid attention, well, a little.. LOL  Anywayz, the clutch, put foot on it to disengage, I don't push it in, just touch it and PTO disengages.  Then I noticed while backing, just barely touch clutch and she stops.  I've betting it needs adjusted, should not be that touchy.  How much play should I have before it disengages/engages, is it easy to adjust?  Never messed with the 190 clutch.
Edited by NDBirdman - 24 Mar 2022 at 5:24pm
John m View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 5:36pm
I believe my manual says 2 inches of freeplay at the pedal. Adust mine on left side between steering console and engine. Pull the cotter pin and remove pin. Lengthin or sharten as needed. Adjustment rod has a large spring on it, easy to spot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 5:48pm
Minimum 2 inches....4 is better as long as you can shift gears
Post Options Post Options   Thanks (0) Thanks(0)   Quote NDBirdman Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 6:01pm
Thanks, I'll definitely do that soon!  I bet that was why when I backed into heavy snow, the blower would stop and tractor would not move.  My only problem, and I seriously hope, is no snow to try her out on again until next fall.  Smile
Edited by NDBirdman - 24 Mar 2022 at 6:02pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote John m Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2022 at 8:14pm
Well I got about 3 1/2 feet in my front yard you can have. For free. Lol
This page was generated in 0.062 seconds.
