WD45 Crank Question |
Post Reply ![]() |
CTALLIS ![]() Orange Level ![]() ![]() Joined: 22 Nov 2010 Location: Northfield Points: 619 |
![]() ![]() ![]() ![]() ![]() Posted: 20 Dec 2021 at 5:28pm |
just pulled the crank (226535) out of a wd45 and found shims on the mains.Thought on the WD's where shimmed.
engine number is 45-85727-G Going to need another crank. Thanks
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21831 |
Main bearings were always shimmed on WC/WD/WD45 gas engines. Rods are shimmed on WC and WD only. New main bearings usually need new shim stacks. If your shim stacks measure .010" each they could be reused I guess.
Thanks for the info
Post Reply ![]() |
