200 hight reduction. |
Post Reply ![]() |
Mikez ![]() Orange Level Access ![]() ![]() Joined: 16 Jan 2013 Location: Usa Points: 8703 |
![]() ![]() ![]() ![]() ![]() Posted: 11 Dec 2021 at 4:21pm |
hello
Could we loose five or six inches if we let some air out of tires. Want to get it into garage to do some work on it. Figured I’d ask and see if anyone has done it before messing with valve stems lol. Thanks
Dirt Farmer ![]() Silver Level Access ![]() Joined: 15 Sep 2020 Location: Illinois Points: 430 |
If it doesnt have a cab just take the muffler off to clear, in my experience if the tires don't have calcium in them the air can be left out to get in garage then air them back up once in the garage to keep from pinching the innertube drive as short a distance as possible with low air pressure.
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54030 |
You could get a mohel to take 6" off the pipe. Won't help if it has a cab, though!
yes sorry. Cab is what we’re trying to clear, and rear tires are loaded. I figured we’d put valve stem at top measure tire let air out tell see fluid see what we got.
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1919 |
If they are full of fluid, you will have fluid coming out before you drop 6 inches. Unless they aren't full. You could get an adapter, valve stem to a garden hose and let some fluid out.
HudCo ![]() Orange Level ![]() ![]() Joined: 29 Jan 2013 Location: Plymouth Utah Points: 3891 |
you can let them down real low even with fliud you do it with the stems on top had to do that in the old shop with 10 foot doors
PaulB ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 5085 |
See what a PIA fluid filled tired are !
CORLEWFARM ![]() Bronze Level Access ![]() Joined: 25 Jan 2011 Points: 115 |
See what a PIA small shop doors are.
BKarpel ![]() Bronze Level ![]() ![]() Joined: 27 Apr 2012 Location: Collinsville IL Points: 113 |
Could make a stand on wheels to support rear end or drawbar support. Then remove the tires and push into shop. Alot of work but doable.
SteveM C/IL ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Shelbyville IL Points: 8611 |
Guess it depends on how bad you need to work on it. Be a good time for a friend with bigger building.
Acdiesel ![]() Orange Level ![]() ![]() Joined: 15 Jun 2012 Location: Rochester Ohio Points: 2576 |
If your barn only has a Dirt or Gravel floor you could dig it out to get under/past your door.
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF D15 SER.2 DIESEL D12 SER.I, D10 Ser.II 2-720'S D21 Ser. II Gmc,caterpillar I'm a pharmacist (farm assist) with a PHD (post hole digger) |
injpumpEd ![]() Orange Level Access ![]() ![]() Joined: 13 Sep 2009 Location: Walnut IL Points: 5094 |
I'd think you could sneak by with a couple of inches, but 6 is probably a bit much.
Edited by injpumpEd - 13 Dec 2021 at 11:55am |
I guess you won't know til you try
lol thanks guys. We let some out tell we felt comfortable and we were like inch or two still to high. So we’re working outside. Funny my grandfather was a dealer here. Before they thought of cabs ha.
Yep: Most building doors were just fine when they were built 50+ years ago.
Post Reply ![]() |
