D12 series 3 oil pressure
bozrae View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Topic: D12 series 3 oil pressure
    Posted: 08 Dec 2021 at 7:19am
What should the average oil pressure be for a D12 series 3 at higher rpm's?
I bought the tractor this past summer and don't know the history on it, the oil gauge looks to have been replaced, but the gauge needle goes all the way to the end.  The gauge is an AC type gauge with the word NORMAL.
I assumed it to be the wrong gauge so I connected a numbered gauge and it reads about 45psi when cold and drops slightly when warm. Most AC type gauges I see for sale for a D12 read from 0 to 30psi, however one vender had a gauge from 0 to 45psi.
D15D, D17G, 170G, 175D, and two 5050FWA
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2021 at 12:37pm
Mine goes to the R on Normal
They don't push a lot of PSI, 45 seems high
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2021 at 1:24pm
The small D series will have higher oil pressure than the low pressure typical of the B,C, RC & CA models. What weight oil are you running? Nothing to be concerned about. I have a D10 that I brought with the knowledge of a known recent overhaul, It will maintain the needle far to the right at all times with 15W40.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2021 at 1:51pm
I'm running a 30wt oil in it. A concern I had is the the pressure release spring may be stuck. But if 45psi is not to far out of the norm I'll just leave it and find a different gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2021 at 5:54pm
As long as the needle is in O R or M, you're OK.  Now if the needle bounces a lot, you might have a problem...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 6:59am
On the AC gauge with the word 'Normal' the needle is buried to the right of gauge and no bounce in needle. The gauge with numbers on it the needle does bounce around at 45psi.
I'll see if I have another gauge around to test and see if that needle bounces also.
Is a bouncing needle the sign of a relive valve or spring problem?
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2021 at 12:03pm
A bouncing needle is the result of an undampened gauge with a 2 vane oil pump. The correct AC gauges has a restriction with a very small orifice to smooth out the pulses from the pump. Be happy with good oil pressure and don't worry about it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bozrae Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 5:44am
Thanks for the responses everyone. I did try another gauge and the needle did not bounce on that one and the pressure read about 40psi when cold.
I'm still curious to know what the oil pressure should be from the factory when it was new. The service manual I have does not say.
Ed (Ont) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ed (Ont) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Dec 2021 at 7:30am
That should be good. It will probably drop about 5 lbs when the oil is warm.
ShellJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ShellJ Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2022 at 7:25pm
I came here with basically the same question, so hopefully nobody will get mad for me popping in since this isn't an ancient post 😁. My D12 oil pressure gauge is rusty and hard to see (original gauge with just "normal" no psi markings) but I can see the needle stays far right even after warmed up. I don't see a warning zone for too high on the original "normal" gauges. So does it sound like my pressure is OK or should I investigate further?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2022 at 7:53pm
You could try hooking up a 45 psi max gauge to it, but the originals are pretty accurate unless leaking or missing the needle...Wink
