Loader Cylinder Operation
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Topic: Loader Cylinder Operation
    Posted: 24 Nov 2021 at 1:52pm
I have a model #17 Allis/Freeman loader on my D17 IV.  The single action cylinders for it, I believe, are for the older D17 high pressure low volume hydraulic systems.  They have worked fine, except their lifting capacity is only about 1000 pounds.  I figured this was because the series IV is a low pressure high volume hydraulic system.  Does that make sense?
I acquired a set of single action loader cylinders for a low pressure high volume hydraulic system and put them on this loader and tractor.  They work fine raising the loader, but when I lower the loader, it seems to put a lot of stress on the tractor/hydraulic pump (the tractor engine actually bogs down a little).  I have a model #180 loader on my one-eighty with the same cylinders, and this stress does not happen with it.  What is the reason for this to happen with the D17 IV and the low pressure high volume cylinders?
Thanks, Dave
Do not argue with an idiot. He will drag you down to his level and beat you with experience. Mark Twain.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 2:14pm
When you put the hydraulic lever in DOWN or FLOAT, the oil in the one way cylinder should easily flow THRU THE VALVE and back to the oil tank... Sounds like you have a restriction in the valve  or line back to the tank...Hose to the cylinder and the cylinder itself is the same if going UP or DOWN.. so if it raises OK, the restriction is further back.
If the engins speed drops, it sounds like you are dead heading the pump to some extent.. Possibly the valve spool position allows the pump pressure ( normally returning to sump when in HOLD or FLOAT DOWN) to restrict the  pump return oil when in the DOWN or FLOAT position...... I think you have a valve problem.
Edited by steve(ill) - 24 Nov 2021 at 2:17pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 3:05pm
Well, put the old/original cylinders back on.  Loader raises and lowers without the stress on the engine/pump.  So, does that means that the issue is with the new cylinders, hoses, or connection?  Guess I could exchange the male hose end from the cylinders that connects to the tractor and see if that makes a difference.  Cylinders are heavy and cumbersome, so don't like doing that too many times!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 3:18pm
Your having trouble DUMPING the oil back to sump at the same time the PUMP is pumping back to sump... Something is TOO SMALL compared to the low volume system.. Hose / COUPLER/ return port in valve.... If the LOW and HI systems are using different COUPLERS, that might be a spot to look ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 3:21pm
Restriction in the hoses ( to cylinders) or cylindersthemselves would case the bucket to DROP SLOWLY .... You also have the MOTOR LOADED problem ... so problem is oil return from the PUMP back to the TANK. .......... something changes between the two systems, or the original valve ports / return hose are just TOO small.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 3:53pm
Whenever you try and use a one-way cylinder on a tractor with two-way hydraulic valves, you will get exactly what you are experiencing.  I hope you have the hose plugged in to the correct outlet??   Pull back on the remote lever to raise the loader??   If you throw your remote lever all the way forward into "float", the loader should drop freely to the ground with no laboring of the engine. If you move the remote lever slightly forward from the HOLD position, you are in the lowering position and the hydraulic valve is trying to send oil out of the coupler that you aren't plugged into on the back of the tractor. The engine should labor!! because it's trying to pump oil and it cannot go anywhere because you don't have a second hose to plug in !!   The One-Eighty tractor will act exactly the same if you place the lever in the same lowering position.  Get two-way cylinders or get used to how this works with one-ways.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 4:44pm
I would think he would have the same problem with the HI pressure system.??? . Modify the valve or run another hose back to sump ??
Edited by steve(ill) - 24 Nov 2021 at 4:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:00pm
High pressure A-C system only had one hose/one coupler and was oil out to raise and oil back in to lower by gravity. Doesn't work like the two-way systems at all.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:15pm
Maybe i missed something.. I though all he did was put a bigger diameter cylinder on the existing loader, with same valve and same tank... just a bigger single acting cylinder.
But i agree, he needs to get oil OUT of the valve back to the tank... why that didnt show up with the old cylinders, i dont know... same pump... same valve.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 7:27pm
I can see when using the high-pressure rams (smaller diameter) how the speed going up and down would be fast....much faster than the larger diameter low pressure rams. So, there is a sweet spot in the activation of the hydraulic spool where oil could be very SLOWLY coming back thru the valve, while not quite applying down pressure at the lowering outlet, hence no laboring of the engine. With the small rams, they would come down faster than the larger rams, so maybe to get the same drop speed, he is stroking the spool just enough farther to now start pressurizing the lowering circuit, causing the engine to labor. It's what is supposed to happen, or the hydraulic pump would explode. And, regardless, the One-Eighty will act the same exact way all things (and I mean everything) being equal. Both tractors have the exact same hydraulic valves !! The One-Eighty has much longer levers, which "feel" a little different than the D-17 IV, but the valves are identical between the two tractors.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Nov 2021 at 10:01pm
Well, to add to the quandary, I had the model #180 loader (which is now on a one-eighty) on a D17 IV before putting it on the one-eighty.  It did not act the way these low pressure cylinders are acting with this #17 loader on a series IV.
I get no push back with the single action cylinders on the one-eighty.  Dad also had a #180 loader on a one-eighty without any issues.  Really strange.
I guess, to finally test things out, I could exchange the male coupler end on the cylinder hoses with each other and see if that makes the difference.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 10:36am
I should further explain.  When I put the low pressure larger cylinders on the loader, they already had the hoses connected to them so there are different hoses and coupler end that connects into the hydraulic coupler on the tractor.  I was thinking, that with the larger cylinders and hose/coupler the loader did not creep down when the tractor was turned off and left sitting.  However, with the high pressure cylinders and hose/coupler connected to them on the loader, it will creep down when the tractor is off and left sitting.  Perhaps it is the hose coupler end that is creating the issue?  Interestingly, the loader on my one-eighty does not creep down when the tractor is turned off and sitting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Nov 2021 at 8:20pm
If no external leak, both should be the same. With a leak in hold poison valve, the small cylinders should leak down faster because of less volume of oil and more PSI on hold poison valve.                           MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Nov 2021 at 8:27am
There are no external leaks.  For the time being, I've decided to leave the old original high pressure cylinders on.  While the lift capacity isn't as great as it would be with the low pressure cylinders, I can pretty much lift 99% of what I'm doing, so go with what works, I guess.
This page was generated in 0.115 seconds.
