Getting gas out of a car gas tank
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Getting gas out of a car gas tank
    Posted: 03 Nov 2021 at 8:31pm
I am trading in my old 2007 Mazda 3, but don't want to give it in with a full tank of gas.  I am looking to get it around a 1/4 tank.  I am not sure if a siphon hose will work going down the filler tube.  I have heard they can get stuck in there.
What's the best way to get some gas out of the tank?  Any ideas?
Thanks in advance!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2021 at 8:49pm
drive it a little while longer...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hubert (Ga)engine7 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2021 at 8:49pm
I can drive  my F250 by it and the 460 will pull all of the gas out of it. LOL The midnight credit card should work fine if it is a smooth hose. Otherwise disconnect the fuel line at a convenient spot and attach a hose to it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 12:12am
yep...use the smooth hose and if the hose does gits stuck trying to pull it out, shove it on in all the way, it won't take up much room in the tank.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 6:36am
Find the fuel filter and hook a small pump to the end that goes to the engine.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 6:46am
Just tell the dealer you need $100.00 more on trade in.
fixer1958 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fixer1958 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 8:45am
You could take the fuel line off the fuel rail and jump the fuel pump relay.
1951WDNWWI View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1951WDNWWI Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2021 at 9:46am
I attached a pressure tester to the port on the fuel injection rail and attached a hose to the relief valve on the tester. The car pumped out two five gallon cans of gas in short order. I think that is why the tester was designed that way.
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2021 at 7:16pm
Have a helper. Remove fuel line from carb. Have a pal use a rag with an air tank, put it in the inlet. Pump air into the tank. Easy.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 6:29am
I could probably put you  in touch with my neighbor's kid. He sure seems to know how to get gas out of my tractors, if I happen to leave one outside.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 7:14am
drill 5/16" hole in btm of tank,put tray underneath first....when drained, plug hole with screw/rubber washer. do this when scrapping vehicles...
really though ,how much gas is in it ? say 80L tank... 1/4 full is 20 L, so maybe 5 gallons. Up here that'd be $30 MAX, you... $15 ??($3/G).
Only way you 'win' is if you're NOT worth $15/hr, cause it'll take you that long(or more) to empty it. Bad news is ..lower it too much, crap in btm of tank (water),gets into engine, won't start, dealer says 'nope...it ain't running like it was, deals off'.....
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 7:21am
I agree Jay, NOT worth the effort for the insignificant gain.  My wife will run a car damned near to empty to trade one in, asked her why and she just wanted her moneys worth yet will buy internet crap to sit on a shelf in a closet for $$ BOOCOO bucks and never see it as a loss or buys/throws away $$$ Healthy Foods I suppose she figures just having in the house and leaving to rot as taste bad is by proxy/Osmosis a Good Diet.  None work out to her fantasy dreams.
Walker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Walker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Nov 2021 at 4:07pm
Drop a lit match in.
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2021 at 11:20pm
Electric pump and long 3/8 hose will work but the pump will cost more than the tank of gas is worth! Leave it in or as stated---- DRIVE it out!
