6060 FWA
MJ79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ79 Quote  Post ReplyReply Direct Link To This Post Topic: 6060 FWA
    Posted: 26 Oct 2021 at 9:19pm
Hello, all.
Anyone know where I may find a driveshaft for the FWA on a 6060? I’ve browsed many websites with no luck. I’m sure salvage yards may have one, but don’t know of any moderately close to Cheyenne, WY.
Thanks!
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2021 at 6:10am
First call I’d make is All States Ag Parts in Salem SD, never know Worthington Ag might have one.  Summerix is worth a try also but Ivan isn’t cheap.  Cook’s in Illinois or Missouri has a reputation for decent Allis inventory.  I have very bad taste in my mouth for Heitman.
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2021 at 7:05am
Mark Heitman treated me perfectly when I needed him. Experiences vary, so he may be worth a try for you.
MJ79 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MJ79 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2021 at 8:23pm
Thanks for the recommendations. I think I’ve searched most of the websites mentioned. Called Wenger’s but the part they has listed was not the shaft I need. May have to call to see if they have parts not listed. Is it the same as 6070 & 6080? May inquire at a fabrication shop to see if they can make it.
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 5:31am
Did you check Countryside tractor in PA 717-923--0421
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 6:20am
Wilson Farms in Bellville, OH?
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 6:27am
Bought a tractor from him went to load it on my trailer rear end was out only moved by fwa.  Got it home found out the PTO shaft was broke off internally in two places and bolts on the oil pan were only finger tight. Check cleared the bank zero willingness to make it right.  I’ve spent twice what I paid for it fixing and it still needs a motor.
He should have sold the “sheet metal” as salvage and put the rest in a scrap trailer.
Acdiesel View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Acdiesel Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 10:38am
heres the link to a guy on facebook that has  a 6080 parts tractor not sure if the shafts the same.
Edited by Acdiesel - 28 Oct 2021 at 10:38am
D19 Diesel,D17 Diesel SER.3
2-D14, 2-D15 SER.II WF/NF
D15 SER.2 DIESEL
D12 SER.I, D10 Ser.II
2-720'S D21 Ser. II
Gmc,caterpillar
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2021 at 5:43pm
What do you want me to say? I believe you. More/less remember your story.
Yet, that’s exactly what he did for me, did right by me. Experiences vary. 🤷‍♂️
Having said that, if I bought a tractor that wouldn’t drive up the trailer in 2wd, I wouldn’t have bought it and loaded it until I knew what was wrong.
Edited by Tbone95 - 28 Oct 2021 at 5:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 11:31am
Not to mention I’ve used the tractor daily for 3 years and hour meter hasn’t moved.
PeteMN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeteMN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 12:23pm
Buy a 12v hour meter and wire it in to the key switch.
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2021 at 3:37pm
How does that play into buying a tractor with only xxxx hours on it?
heitmantractorsalvag View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote heitmantractorsalvag Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2021 at 8:20am
Hopefully this brings closure to this thread.  Victory Allis (Thomas Grabowski) came, drove the tractor and purchased as is knowing the tractor had a bad rear end (see receipt below).  Heitman Tractor Salvage does not pressure anyone into purchasing any equipment that they are unsure of.  If he was unsure of the tractor, he should not have purchased it.  It's that simple.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2021 at 10:46am
So there's the other side of that story!
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2021 at 12:56pm
Receipt is dated May 29th I was not in Wisconsin until JUNE 27th and had not drove it till the evening of JUNE 27th. The receipt proves you knew the rear end was out. Tractor was bought site unseen based off you description.   I’m not new to the fixer upper tractor gig either that 6080 was number 3 out of 4. The guy I bought my 8050 from ended up becoming a good friend and we text back and forth 4-5 times a week.
Michael V (NM) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael V (NM) Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2021 at 2:26pm
How bout a local machine shop building one??
