wd rocker arm shaft broke
markw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote markw Quote  Post ReplyReply Direct Link To This Post Topic: wd rocker arm shaft broke
    Posted: 24 Aug 2021 at 11:59am
is wc  wd45 rocker arm assembly the  same as wd. my shaft  broke 2nd time  looking for parts. why is this happening
DaveSB View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveSB Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 4:42pm
Never heard of the shaft breaking, the stands and the arms yes, but not the shaft.
Is it getting oil to it? Are plugs in the end of shaft good?
1948 C, 1953 CA, 1948 WD, 1961 D-17 Series 2 Diesel, 1939 WC, 1957 D14
plummerscarin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote plummerscarin Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 4:52pm
Perhaps you should lay a straight edge across the head where the stands attach and check the stands themselves to assure they are all the same height?
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 5:12pm
Twice would mean somethings wrong. Are the stands all the same height? Are they evenly torqued? Getting oil?
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 5:21pm
Stuck valve? Hard to beak a shaft. Should be easy to check oil when running at idle, only drips flying around without valve cover.
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 5:44pm
Wanted to point out why I mentioned a sticking valve. Few years ago i bought a barely running wd-45. After replacing the manifold due to several issues and ignition change, cold checking valve gaps, I still had a miss when hot. I popped the valve cover when hot to recheck and my readings were moving. (Shaft had extreme wear and needed replaced when I opened the first time because the oil line was not placed in shaft hole from the PO rebuild). Anyway, I was surprised of the readings were changing reducing valve clearance so I started putting some MM oil in the gas efforts to add lubricant to the valve guides. That was 3 years ago and tractor runs great, and gets used hard.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 24 Aug 2021 at 9:31pm
If it is breaking the outer end off, I would say you have a valve hitting piston or a spring that is bottoming out.                  MACK
Lon(MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lon(MN) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2021 at 5:57am
WC and WD45 are not the same. I have many assemblies on the shelf. email is best lselkriver@gmail.com
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 25 Aug 2021 at 11:49am
It will take one strong @$$ push rod that will not  bend to break off a rocker shaft !!!
nonetheless ,still dead.
