5040 power steering problem
chefiam1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chefiam1 Quote  Post ReplyReply Direct Link To This Post Topic: 5040 power steering problem
    Posted: 08 Jul 2021 at 5:46pm
chef here, well! the power steering reservoir was dry. put power steering fluid in.
raised the front end off the ground.started engine and the steering wheel went totally
left. tried to turn it right but no go would not turn right. shut off engine and i could turn it both ways. opened line to see if there was air in the line. what could cause the steering wheel not to go right? could the pump be bad because no fluid?
                                                 Thanks, chef
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 6:29pm
There is a adjustment for that on the Cylinder .If u wish to call  my shop Friday at 717-634-4398  8 am to 5 pm can walk u through it. Fred
nonetheless ,still dead.
Post Options Post Options   Thanks (0) Thanks(0)   Quote chefiam1 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 9:10pm
fred, thanks i will call in the morning. any special tools do i need?while i have you on the phone. by the way the cylinder fittings are facing down. will that matter ?
                                         thanks, chef
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jul 2021 at 9:17pm
I would say valve is frozen, may need freed up before adjusting.         MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 10 Jul 2021 at 5:50am
I walked him through the adjustment  and  it works now .
