175 Brake part
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Topic: 175 Brake part
    Posted: 26 May 2021 at 11:58am
Hi all,
Anyone tell me the part number of the "X"??  Cant seem to find the part in my 175 parts catalog....also, helluva time getting the circled pin out.  Seems frozen good....
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 6:45pm
Looks like the differential carrier.
 I had to make a puller for a small slide hammer. One end has 3/8 threads which are not labeled on the drawing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 6:52pm
Thats neat Joe!
Know someone who can make me one?  $ for your trouble of course!
I dont understand 100% how these brakes work...so you got these bands similar to the wd45 and D17 that mount on this pin,,,they provide braking contact on the drum...but If i am understanding right the drum sides it self are a braking surface too??  Is this part I want to know about part of that??
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 7:05pm
The band clamps on the drum. the drum has balls that spread the friction plates which press on the the friction discs on both side. friction plates are on the differential housing and the axle housing.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 7:12pm
this part is a braking surface...but why the heck isnt it in the parts catalog???
Anyhoo,,,about that tool you made.....how can I get me one?
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 7:53pm
Part# 70237183. It may or may not be available and the cost could be high.  You could probably have your old one surfaced if that is the problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 8:02pm
Thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 9:13pm
you can machine it down to bolt heads. Just add shims to axel side ware surface.            MACK
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2021 at 9:22pm
After you put the brake assembly back in the housing and put the axle on, you will have to check clearance between the brake disc and the bearing carrier. You may need to add shims to get proper clearance. The tolerance in the service manual - 33 to 88 thou rings a bell but I do not have it in front of me.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 7:23am
I got the AC 175 service manual but there is nothing about brakes.  Is it in the I&T?
So I dont get confused as I easliy do, can you tell me below what parts you are talking about?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 7:52am
Resurface #8 and shims are #9. Measure between #5 and 8.                MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 7:58am
Ok thanks...but part 5/3 slides freely off part 1....At least thats what it looks like as I am looking at it with whole thing taken off the tractor..  What keeps 5/3 in place?
Edited by TomYaz - 27 May 2021 at 7:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 7:59am
Lemme guess...the snap ring!
critter View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote critter Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 10:34am
Joe is there a bolt in that puller to pinch it closed on the dowel?
DanWi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanWi Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 12:00pm
3 and 5 have to float that is what expands to apply the brake the bands only actuate that part to push apart. You brake against no 8 and something on the side of 3. Your clearance would be with 3 and 5 together not spread apart and between 8 and the housing or cover on the other side. Not familiar with the 170/175 but the 190 just has a cover
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 1:17pm
Tom, when I helped a friend get his 175 back to moving, he was short on dollars, thus the fix was as cheap as possible.
We removed the wheel, and then the rear axle.
Then made several measurements... some using a straight edge off of the mating surface of the axle and housing to surfaces.
Measured the old brake assembly after putting new springs in (his had the #2 springs broke).
 Found the dimensions (2.423") of a new #8 friction plate.
 Had a machinist resurface the friction plate face and had a plate made to take the place of many shims. That brought the tolerances back to what was needed to take the slop out of all the wear. Worked good until he sold the tractor.
 Dimension between friction plates is suppose to be 2.034 - 2.044" .  Had a gauge made with those two dimensions, sorta a go and no go gauge, if the narrow side didn't slip in, it was to narrow. and if the wide side slipped in, the area was to wide. Used it only once since it was made.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 2:01pm
Being a computer programmer I am very anal here....
"Dimension between friction plates is suppose to be 2.034 - 2.044" -  you mean between parts 5/3 and 8 with 5/3 being closed?
Based on the other comment, there is a gap between the other side of 8 and the pictured part I posted?  How the heck do you measure that gap??
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 27 May 2021 at 7:04pm
The dimension given is shown in 2nd pic
This is from an I&T manual for a D17s4 (and s3 if I'm not mistaken)
You won't find this in an AC repair manual.
I think they used this basic design in the 175
BTW, Tom, I have made an extraction tool like Joe's to get that *@!*$#* pin out.
I'll look to see if I had made an extra if you're interested.
Edited by Gatz in NE - 27 May 2021 at 7:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 1:46am
I made one like the earlier posted drawing
Joe
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 May 2021 at 6:33am
I assemble everything with new linings. You reach down thru the top hole and measure your disc lining clearance with a feeler gauge. One must assume the shim stack was pretty close to begin with. If you machine any part, you add that amount to the shim stack. I shoot for no less than .020" and no more than .030" with new disc linings. Suit yourself. You can assemble it and measure the distance with some sort of measuring tool, then take it back apart to correct things, or assemble it with real parts, measure and maybe be done the first time. Either way, you assemble and measure and correct if needed.
