D-17 Series II Grease Zerks
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: D-17 Series II Grease Zerks
    Posted: 25 Apr 2021 at 7:50pm
The owners manual I have for my D-17 is for a Series i.  I have a series II.  I see just 2 grease zerks for the front steering.  Does that sound correct?  Thanks in advance!
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2021 at 8:35pm
spindles, tie rods, axle pivot.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2021 at 10:25pm
Original tie rods had no zerks but replacements usually do. Early D17 models had no zerk for the pivot in the front bolster but later ones do.
Wink
I am a Russian Bot
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 6:24am
Series II in 1960 was mostly cosmetic.
Cream wheels, grille, decals; Persian Orange II Paint.
Same time as intro of D-15.
G
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:12am
     I have drilled holes and tapped threads into the probably original tie rod ends on a couple wide fronts on WD-45's. Pumped out some nasty looking grease and have been OK since. The ends were tight to begin with. Did same to front wheel hub caps. Lots easier than disassembly to pack bearings.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 7:25am
Trouble with that on wheel bearings is they need to have the nut adjusted up once in a while to keep the bearings tight.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2021 at 8:00am
Pumping grease through an added zerk in the dust cap could blow out the inner seal.
Some RV's have that 'easy lube' feature.
But you have to remove a rubber Dust Plug to access the zerk which is in the end of the axle.
G
