MS carbs for B,C,CA
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: MS carbs for B,C,CA
    Posted: 26 Mar 2021 at 5:29pm
RE: B&C,CA with Marvel-Shebler carburetors.
In looking through the parts books, I see the B&C used Marvel-Shebler
TSX-154 or TSX-305, the CA used the TSX-486.
Is there much difference between them?  Interchangeable?
Do any of them have an adjustable main jet?
Thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 7:24pm
Brian, someone may have more SPECIFICS for you... all i can say is all the carbs are interchangable between the B, C, CA .......... the very early B had a 116 inch motor, and later B, all C and the CA had the 125 inch motor.. Engine speed was increased also a couple hundred RPM... So if you had a very early carb off a B and put on a CA, you might need the next size jet, or do some adjusting ............. and you know that MOST of the B and C tractors used ZENITH carbs.. But there was a short period one or two years where the MS was used... probably availability problems.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 7:27pm
I think most of the number changes were "upgrades" over the years...Drain added to the bowl, petcock drain instead of plug... etc.... nothing major.
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2021 at 7:29pm
Is it a clean and easy swap MS to Zenith or the other way?
There is the governor rod, choke rod, air cleaner hookup, fuel inlet and the manifold bolts. Is all that  the same?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2021 at 4:00pm
I have moved a couple from tractor to tractor.. Dont remember having any big problems in remounting the rods... inlet and flange bolt face are the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2021 at 7:54am
There isn't any problems with linkage. I changed my 48' B over from a Zenith to a Marvel TSX154. I did it for a comparison between the two Carburetors. Didn't see any difference in performance or throttle response, although I do like the M/S carbs a little better. The 154, & 305 for the B/C applications do not have an enrichment adjusting needle on them probably due to the small engine vs the wieght of the Tractor. They have a fixed jetting system. The TSX159, or 422 for the bigger 201 engines (WC,WD,WF) do have the enrichment adjusting needle on them that extends through the top of the fuel bowl.  HTH
Steve@B&B
This page was generated in 0.191 seconds.
