best carb for series 1 d-17
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: best carb for series 1 d-17
    Posted: 07 Jan 2021 at 1:32pm
I will be replacing the carb on series 1 d-17 soon. Original service manual lists a zenith, but I know afterwards most were marvel schebler. Do you guys prefer one over the other?? Also has anyone tried the look-alike marvel schebler ??  $365.00 seems a little high for a knock-off!!  thanks keith so.va.
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2021 at 2:29pm
You can probably get a rebuilt original from Steve @ B&B.  973 632-5596.  He is a regular on this site.
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2021 at 7:02am
464 Marvel
"Burgie"
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Jan 2021 at 9:49am
According to the parts manual, A-C used one of three models of Marvel-Schebler carbs on Series I tractors starting with Ser. #24001 and continuing through all the Series II tractors.  TSX-561, TSX464 or TSX773.
I think Zenith carbs are good and I have smaller versions on many small engines around the place. In my opinion, the M-S carbs are much simpler to work on.
