E 10 VRS E85 ??
FREEDGUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Topic: E 10 VRS E85 ??
    Posted: 07 Nov 2020 at 8:30pm
Drove past a station yesterday that had regular(E10) for $1.87 and E85 for $1.89. At what price/gallon do you guys call it a draw ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:35pm
i always heard that E85 was cheaper than regular gas, but didn't give as many MPG as regular gas, so i figgered it about evened out. i don't use E85 in any of my vehicles.
Lars(wi) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:36pm
E85, is 85% alcohol, 15% gasoline, correct?
At the prices you stated, you would be getting royalty screwed buying E85.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 8:53pm
My truck can't run the 85, and that's kind of what I thought pertaining to the trade-off in MPG for those that can/do. I'm all for the blended "gasoline" fuels but wasn't sure where the cut-off $/gallon was
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 9:15pm
None of our vehicles can use E85. The cut-off will vary depending on the price per gallon. It is not a static set amount, as the price increases, each additional gallon you use due to lower mpg, changes the equation.
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 07 Nov 2020 at 9:31pm
I had a flex fuel car, HHR. But the mpg on E85 was so poor, I lost money every time I used it. The performance boost however was very noticeable.
I ran E15 in my Honda as it was post 2001, until one day I got a check engine light after fill up. I think it had too much ethanol blended in the code was a fuel issue. Once I got the tank half empty and added some regular it was fine.
1957 D17 Diesel w/ M&W Pistons
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 9:00am
Break even price for E85 is 20% below regular gas, above that is a loss due to the reduced mileage with E85. Have never seen E85 higher than gas personally, but they might as well not offer it at that price. There is a sweet spot I have found with multiple vehicles that E30 actually gives better performance and mileage with cost savings over gas, but you need a gas station with a blender pump and those are not very common outside MN.
Edited by Bill_MN - 08 Nov 2020 at 9:04am
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 10:57am
Paging DaveKamp. Dave has explained this in detail before, pretty sure. Has to do with the BTU's in each fuel.
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Nov 2020 at 7:49pm
Hey Bill, how do they price that out?
I've seen pumps with multiple blends, like 15, 30, 60 or so, but never one where you could pick your own, that would be cool.
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 7:25pm
Pure gas is best.  Keep that damn ethanol out of my engines as much as possible.
Can't burn it in an airplane either.
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 7:33pm
Clay, I do keep E-blends out of the small engines as much as possible, but E-10 seems to be a "sweet spot" for MPG's in the last 3 trucks that I've run , just my observation though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 09 Nov 2020 at 7:44pm
E85 make for powerful pulling engines when tuned properly.
Coke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke Quote  Post ReplyReply Direct Link To This Post Posted: 10 Nov 2020 at 2:47pm
So, I'm on a tractor forum, and people are against the fuel that you grow, in favour of the one you have to pay some other country for?
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 7:56am
On the surface, your observation would seem contrarian.
However, if you dig a little deeper, there are 2 main reasons why the tractor guys and farmers think this way. #1, are all the maintenance and longevity issues with dealing with ethanol. In a car, where you're usually turning over the fuel regularly, not such a big deal. And the car has self-tuning adjustments to deal with different fuels and still run well enough. Older tractors that sit with a tank of fuel for a long time OR need to make power and run great if they're still in farming use, is a different game.
#2, the vast VAST majority of farmers and tractor-country folk are conservative. As such, they in general don't like the government choosing winners and creating false markets and such. Yes, it props the price of corn up for ethanol; the price of beans, sunflowers, Canola, etc. for biodiesel. But it's a battle most farmers will choose to fight.
tomNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tomNE Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 4:18pm
in my world; i use the figure of .65.  the cheaper the gas price is, the more it narrows up!    BUT beware!   you can't take mileage on e-85 until the 4th fillup in the mileage check.  takes that long to burn out the wrong mixture of gas and let the computer catch it's breath and get the right settings!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 4:40pm
How can e85 make any kind of hp in a performance engine  ?? That stuff wont burn with a lighter held to it,, lol,, must have to spend more money just to make it happen ,
Edited by DougG - 11 Nov 2020 at 4:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 6:57pm
Not only that, the mpg goes down, more gallons used to accomplish the same task, the State collects more fuel tax because more gallons purchased. Taxpayer funds money losing ethanol plants, taxpayer’s stuck purchasing sub-par fuel. Taxpayer gets it in the shorts both ways, miserable bast*rds in government created a scam of all scams.
Edited by Lars(wi) - 11 Nov 2020 at 6:58pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2020 at 8:27pm
You are thinking of the same thing Coke, the blender pumps will usually have E15, 20, 30, 50, and 85. The 30% is the one that seems to work best.
Mnfarmboy View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mnfarmboy Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 3:09pm
I have a flex fuel Tundra, using E-85 drastically reduces service intervals.  Cuts them in about 1/2.
Dave
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 3:16pm
how does ethanol change your service interval DRASTICALLY ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote FREEDGUY Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 4:30pm
I can't speak of performance with E85 as my current vehicle does not support it, but when E10 came out in the early '90's, the Dakota I was driving got 1 1/2- 2 MPG better than straight regular fuel SmileSmile.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lars(wi) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 7:46pm
My late ‘90’s Ford Taurus’s always got better mpg on ethanol free gas, by over 2+ mpg.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PaulB Quote  Post ReplyReply Direct Link To This Post Posted: 13 Nov 2020 at 7:55pm
How do you ask: The same way serious racers use methanol alcohol to make serious HP.  Sure it takes a lot more fuel, so what, racing or pulling is NOT an economy run.  E85 is 85% ethanol alcohol which blends well with gasoline unlike methanol. Where rules specify "pump gas" E85 has to be accepted as a legal fuel.  E85 is equivalent to  105 octane race gas (racing gas is not considered pump gas) and allows a higher compression ratio than you can have if you are restricted to 93 octane gasoline. E85 and methanol will cool the intake charge to make the air going into the engine denser than can be achieved with any straight gasoline.
Edited by PaulB - 13 Nov 2020 at 7:58pm
