Traction booster
Zinan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zinan Quote  Post ReplyReply Direct Link To This Post Topic: Traction booster
    Posted: 18 Oct 2020 at 12:47pm
Im trying to figure out the traction booster system on a CA, and I cant find any info on it, how do I use it?
also I think we might put a 3pt on it,  should I get a cat1 or cat2?
Boss Man View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 1:44pm
Cat 1 should be sufficient for a CA
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 6:32pm
1 will hold a ca. that will also give you more equipment choices to use with it. also be lighter on the azz end when raised.
as far as them traction booster things----THEY SUCK!!  got them on wd's and wd-45 and none of them work----you are better off locking them out so they dont mess with you when you are trying to plow!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 8:19pm
The Traction Booster system when adjusted correctly, and used properly, worked just fine on thousands of AC tractors.  Sorry to hear you're sour on them, because they actually do work. If the front end is too light, there needs to be weight added. That isn't the fault of the Traction Booster. The front end has to be heavy enough to allow the TBoost system to do its thing.
Edited by DrAllis - 18 Oct 2020 at 8:20pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 18 Oct 2020 at 9:36pm
Had to remove a washer or two to stiffen the big spring under the 45 pulling 4-16's in 2nd. TB would lift it out with lever all the way down. Worked GOOD as Dr says.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 8:01am
Wow! Not my experience at all. The traction booster on my 45's works so good I can hardly believe it! I do have four stack weights on my 'plow' tractor.
I hope to get a 2-14 plow on my CA someday. Assume you set the TB similar to a WD/45. Set plow down and raise lever back up a little until the gauge shows it working. You can feel it it no or non working gauge.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zinan Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 8:16am
i think its a case of them having to be adjusted perfectly to work good
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 4:27pm
I agree with Mike.  If the linkage is adjusted correctly you can set it even if the gauge doesn't work, you can feel it.  I have the front wheel weights, but I sure wish I had the stack weights.  It's a great system.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 5:43pm
I agree Traction booster is a piss poor idea at best. I HATE using two levers to get full range out of the arms.
Gatz in NE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gatz in NE Quote  Post ReplyReply Direct Link To This Post Posted: 19 Oct 2020 at 5:47pm
for the CA, this might help
WD/WD45 are different
Edited by Gatz in NE - 19 Oct 2020 at 5:48pm
