CA - C & B similarity
Luke114 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Luke114 Quote  Post ReplyReply Direct Link To This Post Topic: CA - C & B similarity
    Posted: 21 Sep 2020 at 4:16pm
Just wondering how many parts are common between the CA and the B & C, or was it a completely different engine, transmission, etc.?  Do bellhousings match where you can do the bolt together Franken-tractor?
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 4:28pm
Engines basically the same except they raised the RPM in the CA to get slightly more HP- interchangeable.
Trans is a 4 speed in the CA, 3 in C and B.
Many people have created mixed tractors.  I have a torque tube from a CA waiting to go into my B.
1951 B
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 4:42pm
most Cs were narrow front end and were a foot wider in the back ( wider final drives) since it was a 2 row tractor... All B's were wide front and overall about 5 ft wide, single row tractor.... hydraulics, transmission, bevel gear, clutch, engine , radiator all about the same on the C and B.
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2020 at 6:38pm
Every thing from the torque tube back on a CA is differant but will essently bolt up to B/C fronts. The wide front C and CA look the same but there differant will bolt up. The narrow front for a CA has a differant casting has more material in it but will bolt to a C you won't be able to use C mounted equipment there's about 1 1/2 " differance the grill Hood And gas tank are similar and will bolt up but have minor differance. You can Frankenstein any of the three if you want.
