WD45 coolant leak
Aaron123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 coolant leak
    Posted: 05 Sep 2020 at 9:57am
On my WD45 and the drain valve on the side of the engine is
leaking i would amagine it would be rusted on pretty good and i would break it if I tried to replace is there something I can put on the end of it to stop it dripping out of the center that can be easily removed? ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 05 Sep 2020 at 8:59pm
It is brass and should come out.          MACK
This page was generated in 0.031 seconds.
