Pertronix EI on a D15
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Topic: Pertronix EI on a D15
    Posted: 19 Aug 2020 at 10:43am
Has anyone put one on a D15?  I can't get the dust cap to sit on the housing properly - even without the magnetic sleeve sitting on the distributor shaft.  The instructions say that the center hole in some dust covers may need to be enlarged to clear the magnetic sleeve.  What is the best way to do this?
This is the first time I have come across this issue.  I've put them on D17s and WD45s with no problems before.
Thanks for any feedback.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 11:12am
Pretty much the same exact distributer as the other two.
BigGuy1000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BigGuy1000 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Aug 2020 at 11:19am
Make sure that the dust cap and distributor are free of any possible dirt, then use a small rattail file to carefully (it only takes a little bit) go around the dust cap center hole until it fits!
