CA engine serial number
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Topic: CA engine serial number
    Posted: 15 Aug 2020 at 2:03pm
My CA is a 1952 according to the serial number, the serial number on the motor I thought should start with CE, mine does not, that number is CR 47015CA. I'm guessing it's been re powered. I can find manufacturing dates on CE engines but nothing on CR engines other than they were auxiliary power units. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 4:13pm
From the replacement parts book.......... look at the B-C piston spec... It would appear the comparison between the CE and CR serial number is about 106,600 motors ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 4:17pm
that might not be the case 10 years earlier. but in your case, your CR number is only 200 motors from the listed serial number.
TomC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Aug 2020 at 4:26pm
I see mine is real close to that cutoff number. I guess it doesn't matter it runs like a top,I figured it had been re powered & was curious as to when my motor may have been manufactured. I certainly appreciate you taking the time to look, I couldn't find anything other than the most common application for them
