WD45 diesel injection pump problem.
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Topic: WD45 diesel injection pump problem.
    Posted: 12 Aug 2020 at 10:58pm
I bought a WD45 diesel today, looks good, I know it's the wrong shade of orange.
It runs terrible, timing is late with lots of unburnt white
smoke, and the governor doesn't work at all.
Whats up with the Bosch pump on this thing?
If it was a Roosa DB2 I'd have it rebuilt already but I know nothing about the Bosch pumps.
The throttle has to be wide open just to get it started, it revs up way more than it should and when you close the throttle, it takes about 8 seconds for the rpm's to come back down, then it dies.
No diesel knock at all, it just sounds weird.
Any help would be appreciated.
Edited by MattLF9 - 12 Aug 2020 at 10:59pm
A little CQB never hurt anybody.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 12:06am
I realized I'm missing the throttle stop on the lever for my diesel.
Anyone have one they want to sell?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 7:48am
Sounds like pump needs timed.            MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 7:56am
Does that mess with how the governor functions?
Just curious.
Michael Crowe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 5:09pm
Matt, get you an IT manual for the WD45 Diesel.  It covers how to time the pump the best of any I've seen.  I've done several, so if you want to discuss, give me a call sometime. I'd be glad to help.  Michael 816 898 7277.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 6:17pm
I have the IT manual, I'll start digging.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 13 Aug 2020 at 9:34pm
That's an unusual statement....they are the worst for everything else
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 4:11pm
Is this correct?
Still can't get it to fire, it's definitely getting fuel.
Edited by MattLF9 - 14 Aug 2020 at 4:18pm
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 5:33pm
the mark in the pump is only for assembling it, not installing it on the engine. That mark is a pointer on the pump drive hub, seems there's a pipe plug to take out to see it. These can really be a pain to get people to understand.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 6:05pm
Matt, you’re not even close. Whoever timed it did not have the directions. Michael
Post Options Post Options   Thanks (0) Thanks(0)   Quote Michael Crowe Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 6:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 9:33pm
Got it running, timing was way late.
This thing sounds similar to the 301 in my F.
The guy that owned it before me used alot of ether to get it started, all the rods are probably bent, it smokes quite a bit yet and misses.
TramwayGuy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TramwayGuy Quote  Post ReplyReply Direct Link To This Post Posted: 14 Aug 2020 at 10:38pm
On my Oliver, the marked tooth ends up about one tooth to the right of the mark. The disc with the actual mark on my pump input shaft was loose and I ended up flow timing it.
Edited by TramwayGuy - 14 Aug 2020 at 10:41pm
