25-40 Engine Questions
steelwheelAcjim View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steelwheelAcjim Quote  Post ReplyReply Direct Link To This Post Topic: 25-40 Engine Questions
    Posted: 17 May 2020 at 11:12am
Just added a 25-40 to my collection and am in the process of servicing the fluids.
What grade of oil is proper for this engine? It has 5 in. pistons and carries about 30 PSI oil pressure when running.
Should non-detergent oil be used?
Thanks.
Pre-WW2 A-C tractors on steel wheels...because I'm too cheap to buy tires!
DaveKamp View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveKamp Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 3:17pm
Hmmm... I'm certain there's others with deeper input than I, but when it comes to older engines, it is my inclination to NOT put a detergent oil in them unless I've first dropped the pan and scrubbed 'em out really good.
Detergent oils have the propensity to break down crud, which normally isn't a bad thing, but when an engine has been run for years with a non-detergent, crud usually settles out to the bottom.  Loosening that up opens the possibility that the crud will get pumped up into the engine.
The other thing to be concerned about... is wether the engine has filtration.  I don't think (unless someone added it later) that your engine has a filtration system... but if it did, it's certainly a partial-bypass system.  No relevant issues if you DID clean the pan out good, but if you haven't, ANY filtration system would be extremely well-exercised, if not overwhelmed, by loose crud.
I cut to the chase on my oldie projects by dropping the pan and cleaning 'em out really good FIRST... and after that, I give 'em a few short-term oil changes with detergent-based.  I CAN tell you that many very picky engine guys add zinc to their oil for purpose of providing soft-metal lubricating properties for flat-tappet engines.  Most oils prior to a few years ago had zinc as a standard additive for that purpose, but EPA mandates took zinc out of the picture.  For roller-follower valvetrain, it's much closer to a non-issue.
Other than that, I always consider the context under which these things were originally built.  Many guys think an old tractor engine needs leaded fuel or other considerations.... they rarely do, as adding TEL to fuel did not START until the late '30s, but didn't gain any popularity until after WW2, and had no benefit for engines with lower compression ratios, and finally, industrial-spec engines had hardened valve inserts as a 'standard'circumstance... on many automotive engines, the seats were just raw iron for the reason of lowering manufacturing costs.  Tractor engines were usually designed to be used in gaseous as well as liquid-fuel applications, so no special fuel considerations were necessary...
Which brings forth one more point-  your 25-40 was rated this way because it was built to operate on either gasoline, or distillate fuel.  Use of the latter resulted in accumulation of unburned fuel finding way past the rings and into the sump.  Being heavier fraction, it didn't cause any significant damage to anything, aside from thinning the lubricating oil a bit.  I don't know if the 25-40 engine had such a fixture, but I once owned an F-series four-cylinder that had a pair of drain petcocks on the oil pain, where the daily procedure for running on distillate was to park it on level surface overnight, and in the morning, open the upper oilpan drain, and let it drain 'till it wouldn't drain any more... to remove the excess distillate from pan.  This would 'thin' the oil, so next oil change would clearly result in loose crud running out the bottom.  My F12 had not seen distillate in at least twice my lifespan, I dropped the pan and mucked out half a coffee-can of black goo... reassembled it with ordinary 10-30 and called it good, and it did just fine on that...
Anyone else got any suggestions for Jim?
Alberta Phil View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alberta Phil Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 4:08pm
I have a '28 20-35 all original.  When I got it twenty years ago, it had been sitting in a shed for about 40 years or more.  It wasn't stuck and I soon got it running.  I drained the old oil which I'm sure was straight 30 wt.  I removed the two inspection covers and cleaned out as much sludge as I could.  I refilled with 15-40 diesel rated oil. and it's been running fine for the last twenty years with no issues.  It's been used occasionally for discing and harrowing and even won it's class in the local tractor pull a few years ago against rubber tired tractors, mostly painted green!
Butch(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Butch(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2020 at 4:18pm
Drain the oil and pull one of the hand hole covers on the left side and take a look inside. If there is a sludge build up that you don't want to remove then personally I would use non detergent oil. If clean then use either one. We have used Rotella 15-40 in our model A tractor since it was restored in 1999. Any motor oil you buy today is better oil than was in it when it left the factory and don't sweat the zinc, it is a non issue with the light valve spring loads in an old tractor engine that runs a few hours a year.
