D17 series IV pulling a model# 73 Plow
Kaptain Kill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kaptain Kill Quote  Post ReplyReply Direct Link To This Post Topic: D17 series IV pulling a model# 73 Plow
    Posted: 06 May 2020 at 12:48pm
I am going to mount an Allis Chalmers model 73 snap coupler plow on my D17 Series IV tractor. The plow has 3 - 16" bottoms. How do I calculate how wide to set the tires?
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 1:08pm
The book I have says 27" from c/l of tractor to the inside of the tire.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2020 at 2:09pm
So, while you have your book out, what is it for a 4 x 14's or 4 x 16's 70 series plow on a D-17 ??
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 12:04am
all the way out.
Well, that was what we had set our 17 diesel when pulling the 4-14 semi-mounted plow.
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 8:06am
The book I have is specific to the three bottom plow. Looked around here and can't find one for a four bottom. My guess is that the measurement would increase by 8 inches, so 35" from c/l to inside of tire would be a good starting point.Maybe someone that has a manual will chime in?
Not sure what the measurement would be for all the way out but JC could be right that is the setting.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2020 at 8:26am
I remember 4-16's behind the 45 required all the way out. Only needed 1 set of stops...
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2020 at 6:37pm
All the way out is what it looks like in pictures in advertising literature. Just wanted to confirm. Thanks.
