Need info on rebuilding hydraulic cylinder
Aaron123 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Topic: Need info on rebuilding hydraulic cylinder
    Posted: 01 May 2020 at 8:05pm
Need info on rebuilding hydraulic cylinders on my 1954 Allis chalmers WD45.. they are leaking and I got the stuff to rebuild it I just not sure how to do it.
Can any on on here walk me through the rebuild? Picture would be nice. If possible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 01 May 2020 at 8:13pm
Rams are usually pitted/scored bad but beyond that,take a pipe wrench or big channel lock and tighten packing nut and see what results are.....otherwise you remove that nut and dig out packing then install new
Post Options Post Options   Thanks (0) Thanks(0)   Quote Aaron123 Quote  Post ReplyReply Direct Link To This Post Posted: 04 May 2020 at 8:19pm
Ok thanks
