How to find 200 serial number
davefullmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmer Quote  Post ReplyReply Direct Link To This Post Topic: How to find 200 serial number
    Posted: 29 Apr 2020 at 7:23pm
My son just bought a 200 not running.  Where do we look for the serial number?
Dave Fullmer
Pictures of my 37 WC with both Steel and Rubber wheels:
http://davefullmer.biz/1937AllisChalmers.html
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 7:27pm
Per TractorData website - Torque Housing right side
http://www.tractordata.com/farm-tractors/000/1/8/185-allis-chalmers-200.html
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 8:35pm
Right side of the clutch housing where it mates with the engine
Post Options Post Options   Thanks (0) Thanks(0)   Quote davefullmer Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 9:43am
Thanks, we found it.  64140 puts it at a 1974.
I see in Norm Swinfield's book that the 74 and 75 were reduced cost tractors.  What did AC do to reduce the costs.  Any significant changes that would be significant?
Dave Fullmer
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 11:41am
The most obvious change was the power director lever was gated as opposed to the lever that pushed down like the 190XT. There was a change in the brake mechanism. There were several changes to the 3 point lift and hydraulics also.
allisbred View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote allisbred Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 12:43pm
Better tractor than XT in my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 1:36pm
Quite a bit better. 50% more lift, a better power director linkage, a stronger final drive, transmission improvements and also a better cab.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Apr 2020 at 1:47pm
Front block under radiator is hollow too, in my opinion the gated PD lever is worse than the push down- if you ever think its slipping replace all bushing and fine tune the linkage for pressure at the hyd spool
Edited by DougG - 30 Apr 2020 at 1:51pm
