Sickle Mower noise
NE GA Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Topic: Sickle Mower noise
    Posted: 26 Apr 2020 at 7:11pm
Hey all, we have been running a No. 3 sickle mower to cut down our small fields. My question is, how much noise should a sickle mower make while cutting? I realize that the mower is somewhere around 60-70+ years old and does have some wear, but I just want to make sure before something catastrophic happens. Pitman is tight on both ends, hold-down fingers are adjusted to where they should be. Knife blades are old but did sharpen up fairly well. It knocks a little bit when under load but gets really loud under heavy grass loads. Is that normal? Also trying to make sure I don’t run it too fast and shake it apart. Op manual says if it shakes the tractor then your RPMs are too high.
What gear should I be able to run this in on a WD or CA? On my WD I know my ground speed is too fast cause I have 16.9x28 tires (taller than 12.4x28) and had to slip the hand clutch in first gear in thick grass but could go full first gear in light grass. On the CA first gear almost seams to slow but cuts good and second gear seams too fast. Anyone have an idea of the RPMs on the PTO that I should be able run the mower at?
Thanks in advance for any help.
Keeping Allis alive with:
2 B’s, 1 C, 6 CA’s, 2 WD’s,
1 WD45, 3 D15D’s, 1 D17
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 9:19pm
Are the guards and ledger plates in good shape? If not and hold downs aren't adjusted properly, they will knock.       MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 9:43pm
I believe the guards and ledgers are in good shape. I replaced the bent guards with NOS guards. How can you tell if the ledger plates are bad?
HD6GTOM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HD6GTOM Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2020 at 10:26pm
Most ledger plates have serrated edges. If you look at a new guard, you can see if they are worn out. Yes in tough grass, a mower with a pitman stick has a tendency to knock a little.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 9:49am
I guess the first thing I would do is turn the drive pulley back and forth by hand to determine where there might be some backlash. Do this at different pulley positions.
A sickle bar mower is inherently a bit noisy but when everything is adjusted correctly, it should not actually "knock".
Clay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Clay Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 11:35am
When cutting wire grass, most mowers will knock.  SLOW DOWN!!!  If not, something on the mower will break.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 12:40pm
New sickle sections will make a world of difference,correct pitman length is critical,those mowers are not made to run fast and do make a certain amount of racket.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 1:36pm
...and ours broke the tube holding the pitman drive...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 3:51pm
This is a good point.......the "register" of the cut bar is one key to good operation.
When the cut bar comes to the end of it's stroke the tip of each knife should be in the exact center of a guard.
On Some mowers with pitman bars the register can be adjusted.
I have a Twin-Wheel mower so I have not had to deal with this.
The other critical measurement when setting up a  mower is giving the cut bar a certain amount of "lead".
On a typical 7 foot cut bar, the outer end should run between 1-1/2" to 2" ahead of the inner end. This allows for the natural deflection of the bar when it is operating.
I still say there should not be a distinct "knock" when mowing.
The quietest mower I ever recall seeing was a rear mounted mower on a 2N Ford belonging to my Wife's grandad back in the 50s.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 4:48pm
The register is correct. I think I found what most of it is. The blade assembly has a little bit of “forward and back” play (forward and back as the direction the tractor is traveling).
Is that adjusted with the wear plates? I have some new wear plates on the shelf.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 4:51pm
I’ve got a second No.3 mower with the same problem.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2020 at 9:51pm
Yes, that is just one more step in setting up the mower correctly.
The wear plates have slotted holes so they can be moved forward to take
up the play.
However, they also wear out and need to be replaced periodically.
You'll have this mower hummin' like a honey bee before you know it.  LOL
only AC orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote only AC orange Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 8:14am
My best guess would be timing - pitman is too long or too short and sickle sections are not "centering" on guards as mentioned earlier!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 9:14am
He says in one of his posts that the register is correct.
ac fleet View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 8:52pm
You can't mow grass with a sickle mower---they NOT designed for that abuse!---They are only for weeds and clover , alfalfa ann that sort of cutting!---AND it's a wonder you have not wrecked it already!--your mower---do as you like with it!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 9:21pm
everyone uses sickle mowers to cut the sides of the road in the country... and they are 90% grass.. If it is  2 ft tall, YEA, you got to slow down, but i cut 12- 18 inch grass pretty often.. Sometimes it clogs up and you have to stop and backup and "dump a load" then take off again.........if the grass is really thick.  I have a side mower on a B... and i normally cut at 2/3 throttle... Im in no hurry.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Apr 2020 at 11:39pm
If a sickle mower was not designed to cut a field, then what was used before the disc/rotary mower was invented?
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 7:21am
Sixth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 7:22am
Sizth.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 7:48am
If they are tuned up[ good I would think they should cut grass pretty well? We cut 60 acres of grass/ old hay fields every year for 10 years when I was a kid. We used a 5 foot antique horse drawn type sickle bar mower hooked to the Case VAI. I got to ride the mowing machine and try to lift the blade when needed. We plugged it sometimes, or ran into a ant hill once in a while. Grandpa kept new sections in it and it purred along pretty well. We never sharpened sections just replaced them.
On clover at my Dads farm we had a 7 foot New Idea pull behind. A field of clover went down in the wind and we had to mow in one direction. About that time Dad bought the New Idea Cut-ditioner (flail chopper) and  the sickle bar was never used again.
Edited by Sugarmaker - 29 Apr 2020 at 8:30pm
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 7:15pm
I guess me, my father, and my grandfather have been doing it all wrong for over 80 years, and never knew it!
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 8:13pm
yea, I hate hearing I was doing it all wrong growing up!
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 9:38pm
Ouch
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 9:39pm
LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote NE GA Allis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Apr 2020 at 9:43pm
My mower works well, just was concerned about how loud it is.
Thanks to all for replies.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 9:14am
Thumbs Up   Thumbs Up   Thumbs Up   Clap
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 9:41am
Wow, so angry!
What the heck did people make hay with back in the day? I know I learned how to cut hay with a sickle mower at age 10, and we certainly didn’t have pure alfalfa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 9:58am
Yeah, use artificial grass! LOL  You can feed artificial cows with it, and sell it to Burger King for Impossible Whoppers!!!Clap
Edited by Tbone95 - 23 Jul 2021 at 9:58am
Ray54 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ray54 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 11:50am
How about we put a 3 D printer inside a big O'l plastic cow  Big smile an Impossible burger can pop out under her tail.LOL End world hungry Bill Gates style.
Dang it how oh how did cutting grass end up solving world hungry. LOL There be one or two very upset at changing the topic. T you and me got to be more careful of letting new guys get us get us in trouble.LOLLOLLOL
Edited by Ray54 - 23 Jul 2021 at 11:54am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 23 Jul 2021 at 12:09pm
