CA hand clutch claification
carco21554 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote carco21554 Quote  Post ReplyReply Direct Link To This Post Topic: CA hand clutch claification
    Posted: 22 Mar 2020 at 7:55pm
CA final drive hand clutch question, "Approximately 0.020" of clearance when the assembled clutch is compressed". To be clear, where is this measurement taken? Clutch facing to primary disk, is my assumption. Sorry, seem to be having a tough time figuring this out! Thank you.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2020 at 9:03pm
When we put in our first hand clutch back in the 50's tried it with the brakes on and it slipped.  Found out there was a gap.  We took it off and ground 1/8" off the three ears that held the clutch together and put it back together.  Worked.  Thereafter when we replaced a hand clutch we habitually ground 1/8" off the ears.  Never had a problem.  Course we not only replaced the clutch we replaced the springs and balls too.
Go to the Knowledge page and you will find an excellent post on replacing a CA hand clutch.
Take good care of the CA.  It is a "neat" unit.  Really nice light two plow tractor.
Good Luck!
Bill Long
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (1) Thanks(1)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 23 Mar 2020 at 9:36am
Compress the completed clutch assy and measure between the friction.
