190xt |
Post Reply ![]() |
festus51 ![]() Orange Level Access ![]() Joined: 26 Mar 2017 Location: Osage City, KS Points: 1644 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Mar 2020 at 3:39pm |
I'm going to have to overhaul the engine in it. I want to do an in-frame. My question is will the oil pan come off with out having to remove any major components? It is raining and I don't feel like getting wet to go look at it.
Thanks
We the unwilling Led by the unqualified Doing the impossible for the Ungrateful
Michael V (NM) ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: NM Points: 2486 |
IIRC, the 'wishbone' for the front axle will have to come off,,,I'm not sue about this,,going from a weak memory, been a long time since I had a 190....
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7530 |
Yes, the front axle needs to be removed. Can't drop the oil pan with the axle in place. Having said that, I would recommend an out of frame rebuild. I strongly suggest replacing the cam bearings too.
AC720Man ![]() Orange Level ![]() ![]() Joined: 10 Oct 2016 Location: Shenandoah, Va Points: 5248 |
Wishbone and front axle I would think would need to be rolled out. I had to drop the wishbone and it’s rear brace and raise the frame just to change my oil pan gasket.
Alex09(WI) ![]() Orange Level ![]() ![]() Joined: 15 Mar 2012 Location: CECIL WI Points: 1754 |
Yes, ike others have said, the frontend needs to be rolled away to remove the oil pan. By the time you do that, another 10 min and you could have the engine off the torque tube for an out of frame rebuild. If you do that, you can inspect the clutch, flywheel, relace rear seal, and replace torque tube input seals, throwout bearing/pilot bearing.
www.awtractor.com
A&W TRACTOR 920-598-1287 KEEPING ALLIS-CHALMERS IN THE FIELDS THROUGH THE 21ST CENTURY |
Thanks for all the replies. I never like the idea of crawling under tractor with out the axle attached. So it will be out of frame and the engine will get the total treatment.
LeonR2013 ![]() Orange Level ![]() ![]() Joined: 01 Jan 2013 Location: Fulton, Mo Points: 3500 |
Never worked on one but from what I hear be real careful about the liner protrusion and fit. Leon
DanWi ![]() Orange Level Access ![]() ![]() Joined: 18 Sep 2009 Location: wttn Points: 1940 |
Technically when the front end is rolled away there is only 1, 1/2 in bolt holding the motor to the rearend so always a good idea to support it when you get that far.
Not a real problem on these engines. Sleeve protrusion is an issue for the older diesels: 230, 262 and 175 cubes.
youngorange2000 ![]() Silver Level ![]() Joined: 27 Mar 2019 Location: eastcentral MN Points: 319 |
I have taken my oil pan off whit out removing the axle completely, I did my in frame that way. I had to jack up the torque tube (using a 6x6 oak block between the jack and the cast housing) intel the front wheels were just off the ground. Then I used a floor jack and wooden block to lift the very back pivot point of the axle just enough to remove the big bolt/pivot pin then when the jack was released there was enough space to get the pan out. IIRC I had to slide the pan forward some then spin it 90* and it slid out no problem. And the oil pump came out no problem with the axle still fully attached at the front. That was my experience with it
Lonn ![]() Orange Level ![]() ![]() Joined: 16 Sep 2009 Location: Назарово,Russia Points: 29817 |
Wink I am a Russian Bot |
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 22107 |
By the time you get done wrestling out six sleeves, six piston/conn rod assemblies, 7 (x2) main bearings, etc, etc, you'll wish you'd have taken the time to just roll the front axle ahead four feet and get it out of the way. Before you do anything, dump 2 gallons of diesel fuel into the crankcase and let it run for a few minutes before you drain it and take the oil pan down. You'll like how nice and clean it is inside after a diesel fuel bath.
Post Reply ![]() |
