lookin for a clue,,,,
desertjoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Topic: lookin for a clue,,,,
    Posted: 06 Feb 2020 at 5:54am
 I have been lookin for some "flanges" I need for a project I want to do,,but when I went to the locale hardware store,,the dude had no idea what it was I was lookin for so I tried Ebay searchin for this,,,,   "2 bolt,  oblong,(or rectangular)   threaded,  1" flange" , am I makin any sense to ya'll here?
Edited by desertjoe - 06 Feb 2020 at 6:07am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 6:09am
OK, I'll bite... WHAT kind of 'flanges' ? or how wil they be used ?
I know of cast pipe flanges.... circles where 1/2" pipe screws in,with 4 holes for mounting...
maybe post a link or picture of what you need.
happy to help since HIS machine is making a bit of a mess up here....Wink
ok maybe this...
https://www.google.com/search?client=firefox-b-d&q=2+bolt%2C++oblong%2C+++threaded%2C++1%22+flange
which leads me to think about flange mounted bearings for your 'project' ??
Edited by jaybmiller - 06 Feb 2020 at 6:11am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 8:13am
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 8:53am
"Floor Flanges" ???
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 8:55am
  OK,,let me try this way. and Jay, your link did not open for me,,,
 Coke, I looked at all of them and did not see the ones I;m lookin for. I very familiar with the 4 and 8 bolt threaded flanges in 150, 300 and 800 and even 1600 pound ratings, but was lookin for the ones that are 2 bolt and sorta oblong or rectangular shaped. I did find some rectangular shaped ones but were only available in 1/2" threaded and mallable iron. I want some in steel and to be 1" threaded. I know they make em just can't remember how they are listed,,,,,,grrrrrrrr
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sugarmaker Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 9:21am
try Mc Master Carr? If they dont have them they probably dont exist?
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 9:24am
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 10:59am
DJ, just grab your torch and make your own flange...Wink
 Jays link, try this one, had to copy and past Jays link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 11:09am
cabinhollow View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cabinhollow Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 11:41am
Take a plasma cutter and cut the mounting base you need.
Then buy some SCH 40 1" pipe x 2" long female coupling and weld to the mounting base.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 1:30pm
 DANG,,,,even tho I worked in Refinery Maintenance Dept for 33 years,,,I never seen so many different flanges,,,,!!!!  I did find one close in the link Mr Miller sent but is brass material,,,,,,I'm headed to the plumbers Shop cause  seems as if I seen some the plumbers use if I can get um in steel and if not,,,I'm gonna do like most say is make my own,,,, I gots a piece of 1/2" plate steel and will cut the pattern I want and weld a 1" S/80 steel collar where I want it and go on with the project,,,,,
 MANY, many thanks , Guys,,,Is what I LOVE bout this group,,,no matter how silly a man;s project may be,,,it's all hands on deck to help him,,,,!!!!ClapClap
johnkc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote johnkc Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 1:34pm
sounds like something I use on my Grundfos pumps for my floor heat system
I support the development of hybrid automobiles and alternative fuels as I need DIESEL fuel for my ALLIS CHALMERS!
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 3:38pm
Image result for 2 bolt,  oblong,   threaded,  1 flange
take a 4 bolt round flange with a 1 inch threaded hole and cut off two of the bolt holes to make it oblong........... some call these Refrigeration flanges
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 5:24pm
  Well,,,I struck out at the plumbers and hardware stores so,,I'm gonna  rely on my shade tree  expertise  and am making my own,,,,I KNOW ole Shameless will be so proud of my "resourcefulness",,,,,LOL
  Wait,,,,wait,,,,I just seen ole Steve's post and that is what I was lookin for,,,,
  Gosh Dang,,,Chit Fire,,,,,I done cut the 1/2" plates out and got some 1" cold roll I had rat holed all cut and ready to weld,,,,,,,
 Steve,,,my friend,,,you done good,,,wisht  I'da seen your post sooner,,,,many thanks,,Guy
 I was gonna buy a couple of 2" 300# threaded flanges at the Oil Field Supply store and do just what you talkin bout,,,but wouldn't you know it,,,they was out of stock on them sobs too,,,,,,,,Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 5:58pm
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 6:03pm
How about Taco circulator flanges? They come in several pipe sizes. Most plumbing supply or places like Home Depot should be able to get them if they don't have them.
Taco flanges
There were some cast iron Bell and Gosset ones below the brass one in DMiller's post with the Grainger link.
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 9:02pm
 Hey Jim.Me ,,,Thanks for your input,,,I think those are the same flanges that JohnKC referred to that go on the grundfos and Taco pumps,but are cast iron. I was really wanting some forged steel flanges as they will be subject to pulling forces that might pull the threaded part from the flange itself. Altho,,,I think the 2"300 threaded flanges have the threaded part in the center of the flange material itself and would be better for what I want to do..Clap
Edited by desertjoe - 06 Feb 2020 at 9:04pm
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Feb 2020 at 10:20pm
Flanders Flanges. They are next door to Cogsley Cogs and Spacly Sprockets.............you can get George to pick them up..........."Sorry Joe I couldn't help myself.🙄
1957 WD45 dad's first AC
1968 one-seventy
1956 F40 Ferguson
Post Options Post Options   Thanks (0) Thanks(0)   Quote desertjoe Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 12:57am
 Thas OK, Stan,,,,I KNOW you meant well,,,,but the last time I called george,,,,,he wouldn't answer the dang phone,,,,,LOLLOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote shameless dude Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 2:20am
Joe...are ya done with all yer other projects yet? and you wanna starts another one??? I think i'll go grease the directional chute on the "machine"!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 5:30am
re: ...as they will be subject to pulling forces that might pull the threaded part from the flange itself...
 That line as me concerned and maybe we can come up with a SAFE and secure alternative solution.
I have some time ,seeing how 'the machine' fizzled out overnight !
Thad in AR. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Thad in AR. Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 6:49am
I don’t have any flanges but I do have a need to know what ole Joe is up to now???
It’s killin me.
Dave H View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave H Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 8:55am
Dave, them there stripper pole flanges look like the ones I used on the fifth wheel to install a replacement ladder.  Whoah maybe i should rename them and put them on ebay.  Think I have some left over ones in the scrap iron pile at this moment.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2020 at 11:04am
DJ, I got ahold of George and told him to call you, he called me back and said you have some sorta iPhone and that those are antiques from the early 21st century and won't work with his system. Wink   Couldn't help myself either. Wink
Edited by chaskaduo - 07 Feb 2020 at 11:05am
mikedes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikedes Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 7:16pm
These are common in hydronic heating and pipe thread sizes from 1/2” to 2”. I bought some from supply house on the net when installing new wood boiler
Mike D
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikedes Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2020 at 7:19pm
Sorry didn’t see you are looking for steel and not cast
Mike D
