6060 value
K bockting View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Topic: 6060 value
    Posted: 21 Jan 2020 at 8:03pm
Looking at a 6060 fwa cab 460 loader
5000 hrs needs cab kit a/c not working 18.4/28 tires 30% few leaks
1 owner just wanting to move 5x6 round bales. Any ideas?
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 8:17pm
Fairly low hours, usually good for 10,000 hours if maintenance has been kept up. Pictures would be very helpful to see the condition. Can’t speak to the reliability of the FWA as ours is 2 WD. Ours is also a open station. Depending on condition you could be $5k-$10k or more if its in great condition since it has a loader and has no mechanical issues. Too many variances to make a guess. They are a very good tractor if taken care of.
Post Options Post Options   Thanks (0) Thanks(0)   Quote K bockting Quote  Post ReplyReply Direct Link To This Post Posted: 21 Jan 2020 at 8:24pm
I don't have any pics sheet metal is good. Will need several $ to fix
A project tractor
WNYBill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WNYBill Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 9:27am
It is a Fiat tractor with an Allis engine.  Make sure the PTO works properly.  It has a duel clutch system,  not 2 stage.  Most of the linkage is cable and may be rusted or frayed or broken.  Read the Owners Manual, if there is one available.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 6:24pm
From what has been said here, they are great when cared for correctly. Can be money put if neglected.
That is my understanding, no personal experience.
210Postin View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 210Postin Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 8:18pm
They are great tractors have 5 of the 6000 series ,no pics of tractor would just guess but if is a good 460 loader it is worth 2500 to 3000 so now to tractor if it is good mech and sound would say 6000 to 12000 lots of unknowns
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 9:08pm
One reason I would walk away from it is if I see the pto clutch disconnect lever pulled back. Talk to the owner to see if he regularly ran it in this position. That’s a huge no no on these engines. The proper use of the pto lever and disconnect handle is covered in the manual. That disconnect handle should always be in the forward position when the pto is not in use and should only be used briefly to disconnect the pto when say traveling to the next windrow with a baler. A lot of discussion on this site about this subject.
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 22 Jan 2020 at 9:34pm
IMO it would have too be at some discount to a 6080 or even 6070.
