Ebay B
Unit3 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Topic: Ebay B
    Posted: 01 Jan 2020 at 6:34am
I don't know how to make a link to it, but it is worth a look. The sellers name is dabie41. This B has power steering down the right side of the engine. It also sports a PTO drive generator.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 7:53am
If you just copy the url address when you are on the page showing it, you can paste it here in your comments and it can be found.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 9:17am
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 11:31am
ANyone else nocitce the generator under the seat ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unit3 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 3:45pm
That's the one.  The paint match on the power steering pump makes one think it might be factor. Interesting place for a generator.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 4:21pm
Do you think they have a double pulley to run the mower and the generator? I don't think I'd want the mower going all the time. Quite the engineering deal.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 5:13pm
Its not factory PS.  Steering shaft has been moved, automotive steering gear, probably, pump and reservoir is also likely automotive, too.  But who am I to judge...Wink
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 7:06pm
looks like its at Biewers tractor salvage in Barnsville MN
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 7:08pm
 The mower wouldn't have to run all the time. If the generator is working right, it would only have to run a few minutes each hour to keep the battery up. just turn the PTO off when you're done mowing.
mdm1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mdm1 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jan 2020 at 7:53pm
My mistake! Sorry. Thanks CTucker cleared something up for me.
