Bleeding hydraulics on 8030
robesonfarms View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Topic: Bleeding hydraulics on 8030
    Posted: 30 Nov 2019 at 5:47pm
I had to rebuild the valve under the steering column on the engine side of the firewall. How do I bleed the air out of the hydraulics? It turns extremely hard. Any help would be great
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 6:41pm
Would think crack a line and turn the wheel
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 9:13pm
I tried that for 4 hours today and felt like I never got anywhere
NomoreJohnDeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NomoreJohnDeere Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 9:25pm
Air would usually cause spongy or intermittent jerky movement?
HD3
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Nov 2019 at 9:32pm
If the effort is high, I'd suspect something is wrong in the seal area of the orbitrol you just had apart.
leoversteeg11 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 7:51am
I had exact same thing happen. Wouldn’t believe that I switched 2 hoses, but I DID.
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 1:27pm
Which 2 hoses did you switch?
Post Options Post Options   Thanks (0) Thanks(0)   Quote leoversteeg11 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 1:46pm
That was a long time ago. 2 of the 4 obviously, but I don’t remember. Bleeding is not your issue , when the hoses are on correctly you can spin the steering wheel with one finger, I guarantee you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 1:53pm
It was very easy to steer before the seals went out
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 1:56pm
I bought the seal kit and the bearing kit for it and replaced everything exactly how the diagram shows. I'm to the point now do I just buy a new valve or try to fix this one again
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 01 Dec 2019 at 8:25pm
Hoses are switched.      MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 9:24pm
Did you get it fixed?
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 02 Dec 2019 at 9:45pm
Hoping to go and try to figure it out tomorrow morning. I do have another question.
On this same tractor how do I figure out which 3 wires need to be hooked up to the bottom side of the alternator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 1:21pm
I put it on exactly how it is supposed to be put on, its locked turning in to the left. I switched the hoses and its jerky, but the wheel will turn in the opposite direction I'm wanting to turn it. Any help would be useful. Thank you
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 4:13pm
I'm afraid the harsh reality is this:  you need to go somewhere and find another 8000 series tractor and VERIFY the hose connections. You have switched hoses and still have troubles ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 7:23pm
I had valve off tractor to put new seal in top(8070) never had to bleed anything at startup....took care of itself.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 02 Feb 2020 at 9:15pm
Did the valve turn free before it was put back on? If bolts were taken out, were they torqued even or over torqued?        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 2:13pm
I went to the local agco dealership and a gentleman showed me the exact way the lines are supposed to go on. I went off that diagram as well. The torque specs said 225 inch lbs of torque.
wekracer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wekracer Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 3:54pm
Did you pull the orbital valve out. If so You may have gotten it out of time. I have heard that’s how they act when out of time. Good luck
Post Options Post Options   Thanks (0) Thanks(0)   Quote robesonfarms Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 4:07pm
Should the tires be straight when putting this control valve on?
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Feb 2020 at 7:58pm
It makes no difference. That valve is nothing more than a fluid director. Turn one way and it puts pressured oil out one line...turn it the other way and it puts pressured oil out the other line. It don't care where the cylinder is positioned when you begin.
Gregor View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gregor Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 9:44am
Just a thought, did you happen to change the hydr filters during this time frame? There is a piece on the end of the filter if not reinstalled, it will act that way.  Been down that road once.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Feb 2020 at 10:10pm
Interesting! Sometimes guys do more than one thing at a time and have a situation show up that is caused by something else but it isn't mentioned.
