23.1-34 tire
MattLF9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Topic: 23.1-34 tire
    Posted: 01 Nov 2019 at 7:04am
I blew a 23.1-34 tire yesterday while combining beans.
I called around to some salvage yards and tire shops, nobody has that size.
Anyone in Minnesota have a good used one?
A little CQB never hurt anybody.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 7:12am
Ideally, you want to find the same size and BRAND as your good tire. If you don't, your header won't be square to the ground and cutting beans cleanly may not happen.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 7:53am
I bought it with mismatched tires and it's been this way for 8 years.
It's always leaned to the left, I call it the Leaner combine.
The good tire is a Co-op, and it's probably the last one in existence, no chance of finding a match.
Chad (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chad (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 12:40pm
You try Midway Farm Equipment, Mt. Lake?  Maybe steve fischer on this site?
220 3-190XT 2-D19d D19g 5-D17 UC 3-WC 2-WD 3-WD45 CA C H3 7-AllCrops 14-plows 3-Gleaners Lawnmowers SC-equipment
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 12:51pm
Yeah, I called Midway immediately and they don't have one.
WLHD21 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WLHD21 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 1:00pm
I have a set of Firestone rice tires from Gleaner G 563-380-4509
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 2:21pm
I don't think what you have will fit my N5.
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 2:37pm
I'm not sure if this company sells used. But worth checking out.   Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 3:15pm
Hey thanks for the link Tim!
They don't have them either.
I'm even looking for the metric equivalent 620/75R34 also.
lowell66dart View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 3:27pm
NTS tire supply has some but their not cheap...
NTS Tire Supply, LLC
205 Industrial Dr
Redwood Falls, MN 56283
Toll Free: 888-787-3559
Edited by lowell66dart - 01 Nov 2019 at 3:29pm
AC 6080 (8030,7060,200,175,D-17HC, 6040,160,6140 all gone) Farmall 1066 & 656 Hi-Clear (for sale), White 2-62 High Clearance, JD 4255 Hi Clear.
Post Options Post Options   Thanks (0) Thanks(0)   Quote lowell66dart Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 3:41pm
EBAY has what look to be blems, new for $899 each.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 5:27pm
Yeah I saw those too, but they removed the name and serial number.
Looks too shady.
DCAC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DCAC Quote  Post ReplyReply Direct Link To This Post Posted: 01 Nov 2019 at 8:06pm
Twin Valley Tire in Milbank, SD, 605-432-4505. Or perhaps Meyer Salvage in Aberdeen, SD, 605-225-0185.
NEVER green View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NEVER green Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 9:00am
I thought Firestone made co-op tires?????   Give Worthington ag a call. 888 845 8456 they have 9 other yards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 6:26pm
There's nothing out there for used tires.
I went ahead and bought 2 shady deal tires on ebay.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 8:58pm
I've got to admit, I've never seen 23.1 x 34's on any N-5 combine. They were always on L-series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2019 at 9:01pm
This is the only N series I have seen them used on.
I think 30.5-32 is the normal tire for these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 9:37am
No complete set tire/wheel 30.5's at salvage worth the money? Probably only set you will need to buy
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 11:53am
It would have been my next option, believe it or not, it would have been more money.
GM Guy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GM Guy Quote  Post ReplyReply Direct Link To This Post Posted: 03 Nov 2019 at 9:09pm
We have a couple decent spares down here in NW KS, but the freight would have been terrible. Mike's Equipment at Buhler KS would have surely had some too.
Sounds like the N5 has the standard finals with the small bolt pattern and someone swapped tires and wheels off a L series, as N5s would have had 20.8x38 or 18.4x38 if it was smaller than 24.5 or 30.5x32.
Gleaner: the properly engineered and built combine.
If you need parts for your Gleaner, we are parting out A's through L2's, so we may be able to help.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MattLF9 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2019 at 8:26am
It has the S25 final drives.
