New Allis Chalmers owner
Scooter90 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scooter90 Quote  Post ReplyReply Direct Link To This Post Topic: New Allis Chalmers owner
    Posted: 06 Oct 2019 at 6:30pm
I just bought a Model  B.  Could not decipher if there was a number next to the shift lever but on the axle housing left of the driver was the number  ?m-2787-13. It has a magneto and  the wide operator seat.  Anyone know what year range this may be?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 6:56pm
Welcome to the forum. If you post some pictures, these guys on here are great for helping. Good job picking orange as a hobby
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 8:30pm
The number is probably AM 2787 13 which is a casting number. The serial number is stamped on the transmission.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:14pm
all of the "B" tractors came originally with a wide seat.. They started building about 1938 and ran for 20 years. There were a few changes, but nothing that you need the serial number to worry about... There might be a MOTOR serial number on the flange at the bell housing area... but the serial number on the TRANS by the shift lever is the real TRACTOR Serial Number..
Very early numbers had hand brakes, and rims held to the hub with rivets. The motor was 116 cubic inch, then changed to 125 inch.  During the war, there were tractors with tall air cleaners, cast iron valve covers and oil pans, and steel wheels... After the war there were very few changes from the late 1940s  to the late 1950s .... when the CA came out after 1950, there were extra lugs cast into the torque tube, etc .... All parts interchange thru the years, so you don't have to worry about the "year" unless your just curious.
chaskaduo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 9:38pm
Serial Number is on the transmission next to the shifter
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 06 Oct 2019 at 10:02pm
What's that picture of, we looked at a B today with a seat set up a lot like that
Edited by Mikez - 07 Oct 2019 at 7:59am
Post Options Post Options   Thanks (0) Thanks(0)   Quote chaskaduo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 7:17am
Serial number says B4800, makes it a 1938 B. It has a aftermarket or dealer add on Monroe Seat.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 8:01am
Oh ok thanks.
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 07 Oct 2019 at 9:49pm
Scooter90,  Welcome to the Unofficial Allis Chalmers Forum.  You have received information from some of the B tractor experts.
I can only ask that you take good care of my favorite.
Good Luck!
Bill Long
ps:  from the posts on this forum looks like my favorite is getting some good owners
JeremyShaw View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JeremyShaw Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 2:25am
Hi man, welcome to :)
Edited by JeremyShaw - 09 Oct 2019 at 4:12am
https://www.agridane.com - Specs of agricultural machinery
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scooter90 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 4:20am
Thanks everyone. I now found the correct number and it looks like I have a 1941.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 08 Oct 2019 at 9:09am
The shop manual could be a helper in maintenance:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
