broken drawbar on 7050
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Topic: broken drawbar on 7050
    Posted: 25 Sep 2019 at 1:24pm
This is the second time we broke one. It has the 13 ft discbine attached. Case DC 132.
My question is:
Has anyone bought a new drawbar from A&I?
Are they good?
Agco price is $940 CAN which seems a bit much...
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 2:35pm
I don't know the answer to your question, I haven't seen a broken draw bar on any of our tractors in close to 50 years of memory!   But I have a question: What is breaking them do you know?  Bouncing?  Binding up/down in hills or something?
Edited by Tbone95 - 25 Sep 2019 at 2:48pm
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 3:17pm
Our green discbine has an extension that slips over the drawbar and extends the pivot back about a foot if case does that I can't imagine the weight of that 13 foot discbine, on the tip then bounce it good and snap
cowkicker View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cowkicker Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 5:30pm
Checked salvage yards? Lots of 7000 series ACs been parted, shouldn't be hard to find. By the way, I have broken one too!
Reindeer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Reindeer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 5:55pm
Might want to check with mhtractor.com in Medicine Hat. Also I have had some parts shipped in from farmlandtractor.com in Oregon.
8070220 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070220 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 5:56pm
I got a good used one here PM me for info
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 6:16pm
Well I'm ordering one from A&I. ($485 CAN) I'll let you know how it turns out.
Yes the wreckers have em, but they're usually worn out too!
The last one I bought at a wrecker and it's now broke. These kind of things you really want to have a good look before you buy.   I had it shipped site unseen last time. The parts guy said it was good. (good for what I'd say?) And now with Greyhound gone, the shipping is a lot higher so I will try a new one.
Here's a pic:
And yes, I do have some hills and some bumps due to mole hills (aka: pocket gophers)
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 7:21pm
In the lower picture it looks like it broke at a hole ? IF so, can you 'fill the hole' with a grade8 bolt and nut ? Maybe even lay 1/2" flat bar stock across the hole to make that area stronger ?
If it's always broken using one piece of equipment, you could remove the 'splint' materials after using that implement.
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 7:30pm
That was exactly my thoughts too Jay...bolt some support onto it!
It does break in the hammer strap mounting holes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 7:41pm
The other part of this failure was that the pto was running when it broke so it smashed around a bit on what was left of the draw bar breaking the u-joint and damaging the shaft.
The down time is costly enough waiting for parts - two days- but I had to go the jobber route for the u-joint because Case/New Holland wanted $1200 CAN for 1/2 of the pto shaft! ($540 for 1/2 yoke)
In the end it was more like $220 to fix the discbine and I stole the drawbar off another Allis in the shed to keep making hay.
The forecast is rain possibly snow the next couple days...climate change. lol
wayne IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayne IA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 8:39pm
Don't know how much room you have, but you may be able to use a chain, or fabricate a bar (pending ability, resources, etc) to go from your 3 point arms under the drawbar to allow the 3 point to help carry the tongue weight.  If using a chain, I would adjust the length to the point that the arms are slightly lifting on the drawbar when they are all the way up.  Just putting a bolt in the hole most likely won't help much since the base metal will still have the weak spot.
soggybottomboy View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote soggybottomboy Quote  Post ReplyReply Direct Link To This Post Posted: 25 Sep 2019 at 9:32pm
We broke the drawbar on our 7045, and the local welding shop welded it back together. He filled that first hole full of weld, and it hasn't broken again. Used a stainless steel rod.
Tenn allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tenn allis Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 4:03am
We have broken several draw bars over the years. Haven’t broken one on the 8070 yet we run a chain under the draw bar to help support the weight pulling manure tanks. Got a draw bar and yoke from a&i on a 4450 now still holding up after 2 years
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 7:31am
Just seems messed up to me.  Seems a 7050 is a right-sized tractor for a 13 foot discbine.  So then, seems a piss poor design issue of some sort with the tongue weight of that discbine they ended up with?
So, does a side load bind it then?  The hitch looks like it hinges up/ down, but side to side whether leaning/ twisting/ or turning looks like it's rigid.  Tractor or mower goes in a gopher hole while the other doesn't, and there's a twist?
Leon B MO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Leon B MO Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 7:53am
I bent the drawbar on our 8050. Got a decent used one, took it to a shop and had a hole drilled in the other end of the drawbar about 5" past the hole that pins under tractor. The drawbar now doesn't stick out the back of the tractor as far but still far enough to utilize a foot of it for an application like yours. We have an 8010, 2 8050's, 8070, 7060 and a 7020. Some drawbars have 2 holes close together at the tractor end, some don't, some drawbars are longer than others. We have had several of our drawbars drilled to shorten them 4 or 5 inches without any problems. It does seem like they stick out the bail a long ways when in the last hole at the tractor end of the bar. There's a lot of stress on the drawbar right at the bail when it sticks out that far.
Good luck
Leon B Mo
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Sep 2019 at 9:54am
I hear ya' Leon, but you have to be careful as well.  540 vs 1000 PTO, the standard dimensions from the end of the PTO shaft to the center of the draw pin.  My 7045 comes out right on that mark with it's two holes.  I know you know that.....just saying, guys should be careful.
