Allis Chalmers B water pump |
Post Reply ![]() |
GPNX ![]() Bronze Level ![]() Joined: 22 Sep 2019 Location: Wisconsin Points: 3 |
![]() ![]() ![]() ![]() ![]() Posted: 22 Sep 2019 at 4:27pm |
I am new to the forum. I recently purchased an allis chalmers b tractor that needs work. The water pump was leaking so i ordered a new one. I have also purchased manuals on this tractor for servicing an maintenance. I have been through books i got all all over the internet and for the life of me can't find torque spec for reinstalling water pump. Does anyone know what it is.
mdm1 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Onalaska, WI Points: 2682 |
Welcome to a great forum. I just put one on a B and just tightened it up. I'm sure someone will know if there is a torque spec. Post some pics of your tractor. Where in WI are you?
chaskaduo ![]() Orange Level ![]() Joined: 26 Nov 2016 Location: Twin Cities Points: 5200 |
You can look up the torque spec for your bolt size on the internet, you also need to know the SAE grade also. Probably grade 5. |
Ranse ![]() Orange Level ![]() ![]() Joined: 11 Mar 2016 Location: Tennessee Points: 775 |
I put one on my B. I didn't realize there was a torque spec. I did just did as mdm1 did, just tighten it. It works and don't leak, I figure it's good to go.
I am in st croix falls wisconsin. thanks for the feed back. for the people that installed the pump did you use rtv sealant like on a vehicle for the gasket?
I used no sealant at all. Just the gasket that came with the pump. I thought about using something, but I haven't had a problem yet.
I think the manual says shellac.
Yep just looked.
Edited by chaskaduo - 22 Sep 2019 at 5:28pm |
I used just the gasket as well. No problem.
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 88256 |
nobody had a torque wrench in 1940 ... Most mechanics are just familiar with "tight" for a given size bolt.. If your not as experienced, then I would use a grade 5 torque for that size bolt and call it good.
Gerald J. ![]() Orange Level ![]() Joined: 12 Sep 2009 Location: Hamilton Co, IA Points: 5636 |
Page B-C-15 in the shop manual I have says "tighten securely" for the water pump mounting bolts.
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf Gerald J. |
BEK ![]() Silver Level ![]() Joined: 05 Nov 2017 Location: Wilmington, NC Points: 216 |
Use anti-seize on the bolt threads just in case you or somebody else ever needs to work on it again.
Lon(MN) ![]() Orange Level ![]() Joined: 11 Sep 2009 Location: Merrill Wi Points: 2037 |
If you need parts I have several of these tractors apart and on the shelf. Just parted another last week. Located in Elk River MN. lselkriver@gmail.com
Post Reply ![]() |
