EMPTY AIR CLEANER??
mikeyD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Topic: EMPTY AIR CLEANER??
    Posted: 20 Sep 2019 at 12:26pm
Was checking tractors for mud dobber nests, shined a light down into air cleaner on my C--no filter elements. Does not seem to be accessible from bottom...does the top come off?
Need to use this tractor but not w/o air cleaner.
Thanks for any help.
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 1:03pm
If you are looking from the top you won't see any as that is a straight thru tube that goes into the oil , then the air goes thru the oil and then through the steel mesh that you can see if looking at the bottom without the oil cup , through the oil wetted mesh and out the side port to the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 20 Sep 2019 at 2:45pm
Thanks, Ted - understand now.
Found a dobber nest in the air cleaner cap - any idea how to keep them out?
The cap has nothing in it to stop them.
TimCNY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimCNY Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 9:12am
Try this:
https://www.ebay.com/itm/153386087149
I wish I'd done this ages ago!
I need more than 200 characters for my "signature." I'd love to see that changed to 250!
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 9:41am
 Shove it full of steel wool. Wink
ACinSC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACinSC Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 2:03pm
Our diesel D 15 had a job like this Donaldson on it at one time . Interesting . Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 2:17pm
TimCNY - thanks for the idea...would not have thought of it.
CTuckerNWIL - thanks, wondered about that. Sure do need to keep them out.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 3:48pm
The shop manual should give air input and air cleaner details:
http://geraldj.networkiowa.com/Trees/Allis-Chalmers-G-B-C-CA-Service.pdf
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 21 Sep 2019 at 7:47pm
Thanks, Gerald J.
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 7:25am
How can it not be accessible from the bottom? That's how you change the oil. How about a picture of that air cleaner?
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 5:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote mikeyD Quote  Post ReplyReply Direct Link To This Post Posted: 22 Sep 2019 at 5:51pm
OOPS - make that #5
