How much fluid? |
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7533 |
Topic: How much fluid?Posted: 04 Sep 2019 at 7:51pm |
How much calcium chloride fluid would there be in a 24.5 x 32 rear tire on a D21? The manual says 1600 lbs of weight, but I need to know how many barrels I will need to drain both tires. I know both tires are near full, but I don't have a clue in terms of the number of gallons. The new tires will be dry, but the cost of them has my eyes wet! Thanks in advance!
old farmer
Silver Level Access
Joined: 12 Oct 2011 Location: Sturgis, Mich Points: 341 |
Posted: 04 Sep 2019 at 7:59pm |
You’re tire man can tell you how much is in your tire by the charts they have.
steve(ill)
Joined: 11 Sep 2009 Location: illinois Points: 88503 |
Posted: 04 Sep 2019 at 8:00pm |
CaCL weights 12 pounds per gallon ......... so 1600 / 12 = 133 gallons.
Jim.ME
Posted: 04 Sep 2019 at 8:09pm |
Found charts that say 140 to 170 gallons of water per tire, depending on the chart. Higher percentage of calcium the less water. Search now much ballast in 24.5 x 32 tire and you will find several options of charts.
victoryallis
Joined: 15 Apr 2010 Location: Ludington mi Points: 2878 |
Posted: 04 Sep 2019 at 8:24pm |
Weight varies by specific gravity |
WF owner
Joined: 12 May 2013 Location: Bombay NY Points: 5052 |
Posted: 05 Sep 2019 at 5:07am |
Just as a reference, when I drained a pair of 18.4 x 28 tires, it took three 55 gallon drums for two tires.
200Tom1
Posted: 05 Sep 2019 at 12:07pm |
Use plastic barrels. Metal ones can dissapear in Les than a year.
Bill_MN
Joined: 12 Sep 2009 Location: Sioux Falls, SD Points: 1471 |
Posted: 05 Sep 2019 at 6:38pm |
