AC Rototiller
bigcreek View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcreek Quote  Post ReplyReply Direct Link To This Post Topic: AC Rototiller
    Posted: 09 Aug 2019 at 9:06am
I recently acquired a 6' AC rototiller but the problem I am having is it keeps shearing the shear pin. I am using it on previously worked ground that is soft and it still shears the pin. Happened 3 times in a row. I can rotate the drum by hand both directions easy and it is coming all the way around and rotating the pto shaft when I do no matter which way I turn it. No hangups. I am using it with a 100 HP tractor, international 856 to be exact. The tiller is very heavily built, too heavy for my ford 800. The furthest I went without shearing was about 50' but the other couple times it sheared the pin after about 5' or 10' of use. Any thoughts on this one?
Thank you,
Josh
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 5:45pm
Post a picture of the tiller, I don't know that AC made one that big...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcreek Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 7:31pm
Well I went out and took some pics of it but wasn't able to upload them for some reason. The model is D 680 if that means anything to you. It isn't like a regular rototiller that has bent tines, the tines on this one are straight. I just don't know the proper name for it?
Krazy Karl View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Krazy Karl Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 8:58pm
What grade bolt are you using. Grade five should be the bolt. I've used those cheap no grade bolts and brother inlaw has also used on misc things and they dont work. One time he said he put one in on a silo blower and it sheared just turning it on
Edited by Krazy Karl - 09 Aug 2019 at 8:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcreek Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 9:19pm
Well heck maybe that is my problem. I used a couple cheapos and a regular shear pin so Ill go hunt down a grade 5. I figured being in soft ground it wouldn't matter but Im probably wrong especially after hearing you say your BOL sheared one just turning the blower on. If I put a grade 5 on it and it still shears Im welding that sucker and going for it. Shocked
truckerfarmer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote truckerfarmer Quote  Post ReplyReply Direct Link To This Post Posted: 09 Aug 2019 at 9:40pm
If the hole is wore, that will shear them.
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2019 at 8:37am
How fast are trying to go.  That seems like a lot of hp for that tiller.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2019 at 12:18pm
Too much HP at too fast a speed and trying to till too deep the first pass will break the pin. An egged out hole for the shear pin will help too. The shear pin is there to save the equipment from being tore up if it is over worked.
 The slowest that tractor will go, is too fast to till anymore than a couple inches at a time. Make multiple passes on the low side of first gear.
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2019 at 5:16pm
As well as I remember seeing one it appeared to be a tiller to work up already worked or plowed land,not to do initial tillage.
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcreek Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2019 at 8:37pm
Soon as I get a grade 5 and try that Ill let you know how it pans out. There is a fair bit of slop in the shear pin hole so maybe that is contributing to it. I had the tractor in the slowest speed it has L1. Ill keep ya posted.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2019 at 9:02pm
I wouldn't weld it, if its  a modern unit, the drive line parts are available.  If not you may be able to adapt a shear bolt yoke to fit.  Or drill out the hole, to the next size up, and use a lower grade bolt to compensate, for the bolt being bigger.  You DON'T want to run a tiller, without any protection, for the PTO of the tractor...Thumbs Down
Another possibility, is that the drive chain and sprockets are worn, and there is enough slap in the chain, to hit the chain case, and kink things up, for just long enough to snap the bolt, particularly if the shear bolt hole is egged.  A simple testis to turn the PTO shaft backwards, by hand, till the tines just start moving.  Then reverse the direction you turn the PTO shaft, while holding onto ta tine and see how much free play is in the chain...
I would think that anything over half a turn would be excessive, and would bear further examination.  Some tillers have an adjustment to take the slack out of the chain, normally a bolt with a lock nut that sticks out of the chain case, which tightens up a shoe, which takes the slack out of the chain...Wink
Edited by DiyDave - 10 Aug 2019 at 9:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigcreek Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2019 at 4:09pm
Thank you DIYDave for the info and suggestions. I will do as you suggested.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2019 at 6:44am
Unless you have a 3 fluted core drill, I wouldn't drill it to the next bolt size. It should be drilled a 1/32 under and reamed to finish size or you will start out with slop in the hole for a bigger bolt. There isn't a drill out there that won't drill oversize of the drill, except where it breaks out at the bottom of the hole.
