D-15 loud noise in 4th gear
Austin1945 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin1945 Quote  Post ReplyReply Direct Link To This Post Topic: D-15 loud noise in 4th gear
    Posted: 25 Jul 2019 at 1:34pm
I'm looking to purchase a D-15 Series II from a neighbor.  It runs out perfect except a very loud whine noise coming from the rear end when driven in fourth gear. All other gears are good with no issues. It doesn't sound like a bearing, more like the bull gear on right side. Has anyone else experienced such an issue and ideas how to fix it?  Thanks
Post Options Post Options   Thanks (0) Thanks(0)   Quote TimNearFortWorth Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 2:03pm
Pretty normal for any D15 to have a howl when run at speed in fourth, have a number of 15's and it'll get your attention when run in 4th if you have not done it for a while.
Still a good idea to check fluid in finals . . . .
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 4:03pm
Our series II has always done that since it was new. But as said above check your trans and bull gear levels.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 5:27pm
I had to replace a bearing in the bull gear of 'Troy', D-14 #1. Replacing it was easy... mopping up the oil wasn't fun though OR the loaded tire....
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 5:31pm
The howl comes from the final drives, most of the time, drop the pans, and inspect, at least change the fluid...Wink
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 7:02pm
Bad brg's on bull pinion shaft on my 45 made it noisey in 4th
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jul 2019 at 7:32pm
i had one with a BAD pinion gear......
You don't wanna tackle that job......
This page was generated in 0.234 seconds.
