1953 CA?
Hunt4Allis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Topic: 1953 CA?
    Posted: 10 Jul 2019 at 11:52pm
So my shop manual for this tractor shows four quarts of oil needed for the motor but does not specify what weight oil it needs?
I'm in NE Ohio and it's been 90 degrees lately, so I'm looking for the best weight oil for summertime going into fall with keeping in mind that I'm going to be using this tractor for a lot of work coming up including running a 5 foot brush hog, sickle mower and possibly plowing?
Thanks Matt
Edited by Hunt4Allis - 10 Jul 2019 at 11:53pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 1:13am
I did find this in the lubrication and service guide...
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 1:15am
So what Ill be best to use is SAE 20 correct?
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 3:03am
I use 15W-40 diesel grade oil in almost every engine I own and its quite a few of them
from 1 cylinders to my Landini with the 354 Perkins.Also  use it in my CA.Oil has changed dramatically since the CA was built.
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 4:37am
When these tractors were built, straight weight oils were the norm. Multi-viscosity oils are better suited for a wide range of temperatures, like the extreme heat you are experiencing right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 5:38am
So 5w-20 or 30 be better?
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 5:45am
Since AC says 10W for cold weather, I would probably not go to a lighter weight than that. I, personally use 10W-30, but a lot of guys are using 10W-40 or even 15W-40. I would hesitate to use 5W, fearing it may be a little too thin to maintain oil pressure on a bypass system.
ac hunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac hunter Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:30am
Dad always used 10W-30 in his WD-45 regardless of the weather / temps since it was new. The tractor has never been overhauled and did all the heavy work on our 160 acre farm for a lot of years. The tractor still runs well but of course is retired now.
HoughMade View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 7:48am
I use Rotella 15W40 in my B year round.
1951 B
Scott B View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott B Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 10:16am
Yep, me too.  D-17, 2 B's and a yet to run CA.  And a diesel Massey Ferguson 231
D17 Series 1
Allis B- 1939
Allis B- 1945
Post Options Post Options   Thanks (0) Thanks(0)   Quote HoughMade Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 10:19am
No 5W20....never 5W20.
Too thin no matter what the temp is.  Plus 5W20 only became a thing in the last several years and is formulated for modern engines with modern metallurgy and only for engines with tolerances and oil systems designed for it.
Edited by HoughMade - 11 Jul 2019 at 10:20am
1951 B
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 4:48pm
We run 15W40 in all our equipment.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hunt4Allis Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 5:30pm
I ended up getting straight 30 weight oil that my agco recommended
DougS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougS Quote  Post ReplyReply Direct Link To This Post Posted: 11 Jul 2019 at 6:07pm
Neither. Use 10W-30 if you're going to use a multiviscious oil. I wouldn't use 15W-40 during the cold winter months either.
This page was generated in 0.250 seconds.
