7060 cab fan wiring?
randy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote randy Quote  Post ReplyReply Direct Link To This Post Topic: 7060 cab fan wiring?
    Posted: 28 Jun 2019 at 5:30pm
I put a new fan motor fan in my 7060 from Shoup and it fit great. But it came with 3 wires and a ground and my old fan only had 2 wires. Would the third wire be for a 3 speed switch? I hooked the wires by color and the fan works, just was wondering. No instructions with it.
Thanks, Randy
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 7:26pm
Some tractors had a 3-speed switch.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Jun 2019 at 8:41pm
They used 2 different motor and switch combinations on the 7080. Later ones, SN 3524 on, used a resistor. There is also a different switch and harness 3101-3523. You would need a wiring diagram to see the correct hookup.
