200 power director |
Post Reply ![]() |
K bockting ![]() Bronze Level ![]() ![]() Joined: 18 Oct 2012 Location: MO Points: 144 |
![]() ![]() ![]() ![]() ![]() Posted: 27 Jun 2019 at 8:44pm |
Issues with low range not engaging or slowly or engaging hard. 75 model with hyd pto and gated shifter. Have cleaned spools on both pto and pd valves.
Rebuilt pd 100 hrs ago. Have not checked pressure yet. Hi range engages properly and have nuetral |
Joe(TX) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Weatherford. TX Points: 1682 |
Check the linkage to make sure it is adjusted correctly. Also look at the rod with the springs on it to make sure it is not stuck. The springs should compress at the end of the travel.
Next I would check the hydraulic pressure.
DSeries4 ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7496 |
Take a look at the mechanical linkage going to the hydraulic valve. Everything should fit very tight with no play. There is a bearing block under floor that tends to wear out, but you also want to look at the connecting pins that can get worn over time. I bought all new stuff for my 190 and it made a world of difference.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21836 |
Service Bulletin 45+ yrs ago to drill a new hole in the outside linkage arm to increase the throw/stroke at the valve spool. That style gate linkage is famous for being short on stroke as things wear.
DougG ![]() Orange Level ![]() Joined: 20 Sep 2009 Location: Mo Points: 8338 |
Theres a bushing in the PD housing that wears on the rod, I always replace it with a broze one , you can get one at a hardware store that fits perfect, makes it all real tight
SIMPLICITY ![]() Orange Level ![]() ![]() Joined: 19 Sep 2009 Location: ERATH LOUISIANA Points: 509 |
MAKE SURE THE LITTLE SHORT LINES THAT STAB INTO THE P/D VALVE ARE ALL THE WAY IN , I REBUILT A 190XT AND HAD LOW SIDE SLIPPING IN FACT I WAS FIXIN TO RE-SPLIT THE TRACTOR AGAIN WHEN I FOUND THE LINE NOT DEEP ENOUGH IN THE VALVE
A pressure check would have caught that problem.
Post Reply ![]() |
